exauhst question
Old Feb 19, 2008 | 09:02 PM
dearhamer's Avatar
dearhamer
Default exauhst question
[hr]
does anybody know if i can relocate my o2 sensor to a welded bung on a long tube header, i realize this would be only on one bank but i want to do some major exauhst mods for off road so no cats and side pipes.
Old Feb 19, 2008 | 09:08 PM
TheForce55555's Avatar
TheForce55555
Default RE: exauhst question
Yes you could do that.
Old Feb 19, 2008 | 09:30 PM
dearhamer's Avatar
dearhamer
thanks. im puting long tube headers on and putting the sensor by the collector
Old Feb 19, 2008 | 09:38 PM
bozzoswald's Avatar
bozzoswald
dont even think about it unless you like to look at your check engine light. you need a cat to change your oxygen content in exhaust no cat no change
Old Feb 19, 2008 | 09:40 PM
jasonw's Avatar
jasonw
Site Moderator
Your best bet would probably buy an O2 sim and just use that.
The Fastman makes 'em.
http://www.thefastman.com/02Simms.asp
Old Feb 19, 2008 | 09:48 PM
TheForce55555
Bullsh*t......................I have a gutted cat and have No CEL
Old Feb 20, 2008 | 02:04 PM
dearhamer's Avatar
dearhamer
i already have a o2 sim for the rear sensor and i have no cat right now and no light, no codes
Old Feb 20, 2008 | 05:25 PM
rabbler's Avatar
rabbler
I'm pretty sure He's talking about the Upstream O2.
It should work installing it in one header but like you said you only read one bank of the engine and the PCM will make adjustments based on just that one side. If your engine is solid and in good tune it probably won't make much difference.
A better idea would be to put the O2 sensor in a cross over pipe but that all depends on what your future exhaust plans are.
Old Feb 20, 2008 | 07:15 PM
SilverRam_01's Avatar
SilverRam_01
For me, no cat=no CEL
Old Feb 20, 2008 | 07:35 PM
dearhamer's Avatar
dearhamer
i have thought of a cross over buy i think i would need pretty tight bends to get to my side pipes. idk
