4x4 posi lock (replaces vac lines for 4x4)
Old Feb 21, 2008 | 12:32 AM
CPTAFW163's Avatar
CPTAFW163
Default 4x4 posi lock (replaces vac lines for 4x4)
I was looking thru the summit catalog when i got my tune up kit and pro flo air cleaner. i saw this posi lock. Its 199 dollars but it gives you positive control of the 4wd so you shift manually into 4wd with the pull of a cable. My vac linewas suspect before the fire, and after the fire i don't know how the hell to route the 4x4 vac lines. Is this anygood? Anyone run one of these?
I figure the dealershp would charge me 200 clams to fix the vac lines, and this comes with instructions so i can do it myself.
What do you guys think?
http://store.summitracing.com/partde...p;autoview=sku
Old Feb 21, 2008 | 01:36 AM
my1500.net's Avatar
my1500.net
Default RE: 4x4 posi lock (replaces vac lines for 4x4)
The posi lock is one of the best things you can do for your truck if you actually use 4 wheel drive or if you ever want to depend on it! I have used one for years because when it snows I use my 4x4 & the factory vaccum system flat out sucks.
Old Feb 21, 2008 | 01:38 AM
CPTAFW163's Avatar
CPTAFW163
Yes, i agree. I think i will get that in the near future. It seems simple enough to do, although meticulous.
Thanks.
Old Feb 21, 2008 | 01:42 AM
CPTAFW163's Avatar
CPTAFW163
Don;t know why my signature didn;t work for showing my pic. maybe it will work now.
Old Feb 21, 2008 | 05:24 AM
v10power's Avatar
v10power
I have never personally ran one, but from what i read from other posts on it here they are great. You know for sure the front axle is either locked in or not, besides from what i read you can use 2lo if you need the extra torque if need be which in times can be good at times.
Old Feb 21, 2008 | 07:23 AM
dhvaughan's Avatar
dhvaughan
i've got one and i really like it.
my favorite feature is the ability to ease around in 2wd low.
here's some intall tips.
https://dodgeforum.com/m_718119/tm.htm
i think you can find it for about $20 cheaper. check amazon.com
Old Feb 21, 2008 | 09:48 AM
zique's Avatar
zique
I have one as well. If you search around on here, there's quite a few of us actually. Install took me about 30 min.
Old Feb 21, 2008 | 10:07 AM
dhvaughan's Avatar
dhvaughan
ORIGINAL: zique
that's because you won't stop and take PICTURES !!!!!
