mpg's
Old Feb 21, 2008 | 04:11 PM
rwarrenh's Avatar
rwarrenh
Default mpg's
I own a 2000 dodge dually ram 3500 4x4, I Really NEEEED more mpg. Avg. 9.7 mpg all around empty!! I have installed the following: true duals,spacer under throttle. air intake. upgraded ignition coil, wires, distributor cap. leveled the front. and i am running 315/75/r16's.I am really in need of help here, my wife is going to make me sell if i cannot get better mpg. I am easy as can be on it(baby the throttle every where).no codes from computer, run 89 octane fuel(+)going to replace O 2 sensor over weekend. PLEASE help if you can, it's an automatic trans.I have also put royal purple products everywhere and just had the front end aligned!!B&G intake cleaned as well. thanks!
Old Feb 21, 2008 | 04:13 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: mpg's
Run a smaller tire for starters.
Old Feb 21, 2008 | 04:29 PM
zique's Avatar
zique
Default RE: mpg's
First is to search on here (in the links up top), there's a bit of advice to getting better mpg's. Silver has one of them, but here's my list:
1) Smaller tires
2) Check your plenum
3) Remove that stupid throttle spacer and use the money for gas!
If you really "NEEED" better mpg's...you are driving the wrong vehicle...go get a geo metro.
Old Feb 21, 2008 | 04:55 PM
ICEMAN_CH's Avatar
ICEMAN_CH
Default RE: mpg's
have you recalibrated the PCM for the bigger tires?
Old Feb 21, 2008 | 05:01 PM
Silver_Dodge
Default RE: mpg's
Check your cat too.
Old Feb 21, 2008 | 05:02 PM
dhvaughan's Avatar
dhvaughan
Default RE: mpg's
trade it for a cummins. you'll not get any decent mpg out of a gas burner.
Old Feb 21, 2008 | 05:38 PM
8t5gt's Avatar
8t5gt
Default RE: mpg's
u run 315s:| did u re gear?
Old Feb 21, 2008 | 05:48 PM
jasonw's Avatar
jasonw
Site Moderator
Default RE: mpg's
ORIGINAL: zique
+1. Get a Fastman TB if anything.
Old Feb 21, 2008 | 05:53 PM
1BigRamaniac's Avatar
1BigRamaniac
Default RE: mpg's
Four wheel drive+huge tires=you are doomed to low mpg. I get 16 and have a 2wd, drive 55, 98% hwy too. Iman up and shell it out.
You knew what you were getting into with a 360 4wd anyway, 6000+lb truck anyway.
Old Feb 21, 2008 | 06:32 PM
sbrunn9's Avatar
sbrunn9
Default RE: mpg's
Wouldn't it be a v10. He said 3500.
