not idleing...
Old Feb 21, 2008 | 11:24 PM
cg121190's Avatar
cg121190
Default not idleing...
truck idles fine until i drive it for about 5min then it wants to die whenever i come to a stop sign or when ever i let off the gas, to keep it running i have to put it into neutral and keep it reved. sometimes it also smokes from under the hood i think from the valve cover area.. any suggestions on what could be wrong
Old Feb 21, 2008 | 11:51 PM
padodgeram's Avatar
padodgeram
Default RE: not idleing...
1st: the idle , clean your IAC behind , on the throttle body , you will need a #25 torx to get the screws out (2) becareful not to damage the IAC plunger just clean the tip and shaft with brake cleaner and gently wipe it down..
2nd: if the valve cover has a leak then its time for a valve cover gasket...
Old Feb 22, 2008 | 12:10 AM
EricCartman's Avatar
EricCartman
Not sure about the smoking from under the hood... but I had a DEAD battery the other day, and it would not very well at all after a jump start. Once the RPMs fell... the truck died. It ran really bad until i was able to pull the battery and put it on the charger.
Cartman
Old Feb 22, 2008 | 12:30 AM
motorbrreath's Avatar
motorbrreath
check the idle air control...
Old Feb 22, 2008 | 10:03 AM
dusty_duster's Avatar
dusty_duster
ORIGINAL: motorbrreath
+1
The IAC may be bad. Try cleaning it very carefully first. Use throttlebody cleaner on it. If that doesn't fix the problem, replace it.
Old Feb 22, 2008 | 01:52 PM
cg121190's Avatar
cg121190
ORIGINAL: padodgeram
yea i'll try cleaning that and as for the valve cover i just bought the gaskets, thanks
