Overheating
Old Feb 26, 2008 | 01:38 PM
Big Country96's Avatar
Big Country96
Default Overheating
I have a 96 ram 5.9. It overheats to 230 and sometimes higher. It bounces around from 200 to 230 once ive been driving a while. When my truck is running the coolant doesnt curculate itjusts sits there so i replaced the thermostate and its still doin it. Does anyone know what else it could be.
Old Feb 26, 2008 | 03:45 PM
kurts2's Avatar
kurts2
Default RE: Overheating
First feel around the radiator once the engine is hot. If only part of the radiator is hot, it's plugged up and needs to be flushed/rodded, or replaced. If the engine is hot and the entire radiator is cold, it's prob the pump. Do you get heat from the heater vent?
Old Feb 27, 2008 | 09:15 AM
Silver_Dodge's Avatar
Silver_Dodge
Moving to 2nd Gen section, bump to the top.
Old Feb 27, 2008 | 09:36 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Check the thread in my sigline about running hot. Could be an air pocket or it could be a worn impeller on the water pump.
