is possible to put a 410?
well, just for curiosity, is possible to put a 410 small block engine instead a 318 without having to modify the engine room?
or the biggest one for the 2nd ram generation is the 360?
I'm not in a hurry, is just to know a little more
thanks
thanks
Anything is possible, as for as room there is plenty i think u would be able to fit a viper engine underneath it. You will proably need new motormounts, transmission, and alot more that other would be able to help out with.
goto a junk yard and get the 488 v10 that came in the 2500 rams and drop it in i think it would be fairly easy to bolt in i would assume the mounts are the same or bore out a 360 to a 408 and it will just bolt in place of the 318
4.04" Bore on a 4" stroke... Alls ya need is some pistons and rings out of a 360, and a 4" Eagle 4340 Forged Crank plus a balance job, some bearings and may as well get yoself a windage tray while you rework that motor of yours... 410 smallblock right there based on the good ol Mopar 273 smallblock A engine. Shouldn't cost more than about $1500 buckaroos.
Mopar Performance has shown
408, 426 and even 440 cubic inch small block V8
stroker kits in the past
Trending Topics
I was checking out books online and I believe that it's even possible to make a 476 smallblock. Capable of being driven over 100,000 plus miles like a 410 stroker built with high quality materials without a complete teardown? I don't think so.
http://www.amazon.com/gp/product/193...pf_rd_i=507846
