New Throttle body and tuner question????
Old Feb 28, 2008 | 08:45 PM
HammerNailKid's Avatar
HammerNailKid
Default New Throttle body and tuner question????
Okay, I know there are a ton of threads about TB's and tuners on here, but I'm hopin this will be faster than searching through them all. I just got a superchips tuner and plan on running it on my truck this weekend ('98 1500-5.2-4x4). However, I've also ordered a fastman 50mm TB, which should arrive in 1-2wks. My question is, if I go ahead and tune my truck with the programmer now, will I need to run the program again after I install the new TB? If thats the case I"ll try to contain my excitement and wait to do it all at once.
Also, on a side note, has anyone installed a 2" leveling kit?Just wondering if it's worth it or if Ishould skip straight to a lift.
THANKS A TON!
Old Feb 28, 2008 | 08:52 PM
Ram2K1's Avatar
Ram2K1
Default RE: New Throttle body and tuner question????
You should be fine to go ahead. The tuner won't have to be reloaded after the TB install. It changes your pcm, so it doesn't really matter. There are a few people on here with a level kit I believe. I am going to level mine, but I chose go springs rather than the spacer. You can either get springs from an off-road model or 2500 model. The ride would be rougher, but you might find some for cheap. Or you can pay about $160 for Skyjacker part # D20 which gives you new springs and a 2" front lift.
Old Feb 28, 2008 | 10:38 PM
HammerNailKid
Thanks for the response Tim
Any other opinions out there?
Old Feb 28, 2008 | 10:47 PM
hometheaterman's Avatar
hometheaterman
Yeah I don't think a tuner like a Hypertech or Superchips would make a difference as it doesn't set anything differently if you have a tb. If you went with a custom flash you where you could change it if you had a tb installed or not might matter but with a Hypertech or Superchips you should be fine.
