aftermarket fog lights
Old Mar 1, 2008 | 10:25 PM
iowaman0322's Avatar
iowaman0322
Default aftermarket fog lights
i want to hook my fog lights i just bought to the head light switch like it says.. but the haynes book i have the wire colors don't match. the instructions that came with the lights says to connect to the low beam so it'll be on with the low beams only... does anyone know what the color of the wireis by the switch. or possibly the oem fog lights so they turn on with them. i have a 98 dodge ram
Old Mar 1, 2008 | 11:37 PM
Ram2K1's Avatar
Ram2K1
Default RE: aftermarket fog lights
Hook it into a separate switch, so you can turn them on with your high beams...or by themselves if it's really foggy.
Old Mar 2, 2008 | 11:04 AM
iowaman0322
is it safe to keep taping into the switched wire running from the radio or is there another wire i can tap in to
Old Mar 2, 2008 | 11:35 AM
WD OPN Throttle's Avatar
WD OPN Throttle
I don't know about 98's but 95's they used whatever colored wire they could. Try popping out the fog light swithch and tracing the wire that way.
Old Mar 2, 2008 | 12:12 PM
Silver_Power's Avatar
Silver_Power
I just monted a Switch and ran threw lights/battery/ and switch. Simple. Just make sure to run a fuse and relay.
Old Mar 2, 2008 | 12:34 PM
Aubrey's Avatar
Aubrey
They changed a lot from 95 to 98 so I don't know for yours. But, when I put mine in, I now wish I would have tapped into the parking light wire. If you have a set with relay and all, then you're just using that power to switch on the relay which then draws power from a wire from the battery. If you're wanting to power them off of the same wire as the low beams, I'd think twice. You'll lose a lot of brightness trying to power them both through the one low beam wire.
