flushing coolent system
Old Mar 1, 2008 | 11:14 PM
pipeking's Avatar
pipeking
Default flushing coolent system
i bought a coolent clener bcause my system is full of nasty.should i flush it and run the cleaner with no t-sat for the time suggested on the bottle
Old Mar 2, 2008 | 09:24 AM
fivenine ram's Avatar
fivenine ram
Default RE: flushing coolent system
i would think youd need to pull it out so that the flush could flow thru constantly when the engine is running but wait for someone else to post because im not sure
Old Mar 2, 2008 | 10:07 AM
aim4squirrels's Avatar
aim4squirrels
Are you replacing the t stat? If not, you'll want to clean that too as its a source of bottle necking and a collection point for crud.
All you need to do is put the cleaner in and run the truck for 10 mins. It'll run it through everything and the t stat will open by then. Make sure you completely flush out the old coolant BEFORE you put the cleaner in.
Old Mar 2, 2008 | 01:31 PM
WayneC's Avatar
WayneC
I would replace the t'stat if the system is that cruddy. Cheap insurance. Flush 1st tho as AIM described above.
Old Mar 2, 2008 | 04:09 PM
pipeking's Avatar
pipeking
ya im replacing the t stat to a 180 i have to do the plentum leak job so ill b doimg a complete overhaul.so it would be a good idea to run the cleaner with out the t stat in right?
Old Mar 2, 2008 | 04:18 PM
aim4squirrels
sure, that won't hurt at all. Just reconnect the hose, HAHA.
Old Mar 3, 2008 | 02:16 PM
pipeking's Avatar
pipeking
i guess that would be a good idea contant flow.i have a hose adp. to hook a gardan hose up and power flush.
