intake manifold ?'s
Old Mar 2, 2008 | 11:25 AM
motorbrreath's Avatar
motorbrreath
Default intake manifold ?'s
so the engine came with everything except an intake manifold. so i gotta find one. How much should i pay for one? also, i take it that only 94-96 intakes will work because its egr? or will like a 93 work?
Old Mar 2, 2008 | 06:17 PM
motorbrreath
Default RE: intake manifold ?'s
bump... yall know if a 93 intake will fit on our trucks? got someone that has one for me.
Old Mar 2, 2008 | 06:33 PM
rabbler's Avatar
rabbler
I don't think it will.
I don't think they used multi port FI until 94 on the magnum v8.
Whats this manifold from?
have the guy send you a pic. If it looks right it should fit. I think 94-95 is the only year that will fit with EGR. I've never seen a 96 with EGR but its possible California built may be different.
Old Mar 2, 2008 | 10:36 PM
Ramsrush's Avatar
Ramsrush
Can you use the one that's on the truck now
Old Mar 3, 2008 | 01:38 AM
motorbrreath
ORIGINAL: Ramsrush
nah... cause then i wouldnt be able to drive it. this is the old motor out of the truck, the new one is from a 98 so they had to swap intakes.
so i guess the quest contiues. Are there any aftermarket intakes worth lookin at?
Old Mar 3, 2008 | 08:30 AM
turkeyhunter1962's Avatar
turkeyhunter1962
I don't know where in Georgia you are from, but I found several in Georgia prices between $75 and $125 on www.car-parts.com. Do a seach there and hopefully you find one local to you. Also sent PM to you.
Good luck.
Old Mar 3, 2008 | 10:29 AM
RM_Indy's Avatar
RM_Indy
Keep looking for the 94/95(my 96 came non egr), otherwise you will have to get an M1/2BBL w/egr which are about 650 new.
Old Mar 3, 2008 | 12:44 PM
svehn's Avatar
svehn
motorbrreath, i'm pretty sure a 93 will fit. The 93 motor was the first of the magnum 360's. they were mpi. pretty sure they were egr like the 94-95 engines. the 318's went magnum(mpi) in 92 and the 360's went in 93. then in 94 the v10 magnum was introduced. the v6 was magnumed in 92 with the 318. i know the dakotas were like this and im pretty sure the rams were too. according to www.dodgeram.org, 1993, 360's, were mpi in the 1/2 ton, 3/4 ton and 1 tons as well. i dont know about the egr, but i imagine they were. good luck searching
