2wd lift kit?!?!?!
Old Mar 7, 2008 | 04:28 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: 2wd lift kit?!?!?!
Put a locker in and get some beefy tires and you could hang with most 4x4's.
Old Mar 7, 2008 | 04:57 PM
Cereal Killer's Avatar
Cereal Killer
You'll knock a 2 wheel drive truck out of alignment everytime you take it offroad, trust me use to have one. Broke the frame in half trying to take it somewhere I shoulnd't have.
True though, if you get alocker and some beefy tires you will get some decent traction out of it.
Consider selling it for a 4x4 that is a couple years older and you should walk away from the deal even, or a little ahead of where you are now.
Old Mar 7, 2008 | 05:28 PM
sk8ordie's Avatar
sk8ordie
ive thought about it cereal killer but i just love saying that to my brother and all his friends. the look on their face is just priceless!!! anyways the locker does sound like a good idea where do i get those from and about how much. as for the tires i am going to get beefier ones but i need the lift first or can i get away w/ a body lift?
Old Mar 7, 2008 | 06:40 PM
sk8ordie's Avatar
sk8ordie
so i take it that no one thats 2wd has a lift??? oh well ill figure it out. i appreciate the help though. if any one knows please PM me or speak up on here.
Old Mar 7, 2008 | 06:46 PM
Cereal Killer
Well there's only one REAL option for locking a 9.25 and that's a detroit locker. They run about $600
Here's a site that'll help you with the install
http://www.offroadexchange.com/detroitlocker.htm
Old Mar 7, 2008 | 06:54 PM
4x4fantasy's Avatar
4x4fantasy
ya know, you could just do a body lift.
Old Mar 7, 2008 | 07:00 PM
Cereal Killer
Yeah he could just do a body lift
and he could keep dragging his frame and his transmission and transfer case off the ground...
Old Mar 7, 2008 | 07:01 PM
4x4fantasy's Avatar
4x4fantasy
what transfer case? he is 2WD!!
I also found that Daystar carries a set of coil spring spacers for his truck, $40 at a retailer I found.
Old Mar 7, 2008 | 07:06 PM
Cereal Killer
ORIGINAL: 4x4fantasy
wow silly mistake on my part.
2wd don't have a skid plate either do they?
I mean a body lift is fine if you just want to clear bigger tires (which you'll need anyway) but since his main problem is ground clearance I'd say a suspension lift is in order. I know there's 3" suspension lifts for 2wd truck out there because this topic comes up about once a week, but I can't remember the names of the companies.
Old Mar 7, 2008 | 07:09 PM
4x4fantasy's Avatar
4x4fantasy
The only lifts I found while doing a search was for 1" springs, coil spacers, and 3" blocks in the back. Cheap, simple, effective.
I used to have a 2wd truck, and I could get spindles, springs, spacers, all kinds of neat things for it. But that was back in the early 90's.
Just offering my .02 to the fella.
