Need some help.
Old Mar 7, 2008 | 03:55 PM
veilside3kgt's Avatar
veilside3kgt
Default Need some help.
well I still have a problem with my 2001 ram; when I take off from a dead stop even at 1/4 throttle it feels like there is a sudden "thud" under the middle of the truck. I went underneath the truck to check the transmission mount...looks very good.. I even attempted to tighten the bolts on it...they are tight. I checked my front end joints they seam tight...is there anything else it could possibly be. The only way it does not do it if I let it coast for a second or two and then hit the gas after it is already rolling.
Old Mar 7, 2008 | 03:58 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: Need some help.
U joints or an engine mount are your most likely culprits.
Old Mar 7, 2008 | 04:21 PM
wvjefo's Avatar
wvjefo
I agree with Junior. Check your U joints & engine mounts.
Jeff
Old Mar 7, 2008 | 04:33 PM
veilside3kgt
That's my guess how hard are the U joints to replace on these trucks? Thanks
Old Mar 7, 2008 | 04:54 PM
mopowar's Avatar
mopowar
Not hard. Harbor Freight sells a u-joint/ ball joint service set for ~$35. Or it was when I bought one anyway.
Old Mar 7, 2008 | 05:41 PM
veilside3kgt
awesome thank you very much.
Old Mar 7, 2008 | 07:16 PM
TheForce55555's Avatar
TheForce55555
All you need is socket and a hammer to change u-joints, dont buy any special tools
