has anyone had a pcv valve stuck in the vavle cover? im doing a tune up and i cant get the pcv valve out. everytime i pull hard on it it feels like its going to break.ive only had the truck for about a month so im slowly going through everything and changing stuff so i know that its been done truck has 125000 on it so im thinking that it hasnt been replaced in awhile. i appreciate the help
it takes a little time but it should eventually work itself out, i doubt you'll break it and if you do then take a pair of neddel-nose pliers and pull out the last bit of it, goodluck
My '96 5.9 Ram & my '94 5.2 JGC has a rubber has a rubber grommet that holds the PVC valve in place in the valve cover. Can't you just pull & twist to remove the PVC?
