fuel filter questions
hey guys, im pretty sure my fuel filter has 200k on it is it hard to change? i work at a kia delearship and the tanks rust out so fast that u need a new tank cuz the screws seize and strip to get the pump out. is ours bolts or screws to change it? is it hard ?
any pics or diy would be sweet
thanks!
thanks!
the fuel filter is on the pump assembly its self. i dont know if it can be changed. Maybe so. Good Luck.
+1 on the DIY, its very straight forward. Just hope you can get the strap bolts off [8D] i still cant get the front one to budge. Damn canadian trucks.
i have to do mine it is going . i always thought it would be easyer to lift the bed instead.the gas tank is a pain in tha *** strap bolts ussually rusted bad and hoses arnt long enough to drop you gotta lossen the tank up and then reach where you cant see to get them off it a big pain. i would like to hear from someone who has done this and see, i bet it would b easyer to lift the bed
ORIGINAL: wvjefo
You got to drop the tank. That is the hardest part. The next hardest part is NOT catching Fire. Get a Haynes or Chiton manual. Really handi to have.
Jeff
Jeff
Trending Topics
omg i never even thought of our tanks being plastic, my bad
embarrased much:P ok thanks alot guys. were supposed to be getting 50 cm of snow here so f the tank till a couple months
ORIGINAL: VWandDodge
Say what? The tank is plastic, the fuel pump assy nut is plastic -- hell, most everything is plastic. Common sense would dictate no smoking or open flame when working on the fuel system.
ORIGINAL: wvjefo
Jeff
Jeff
Incandescent trouble lights should be illegal. Fluorescents are only slightly safer. LED is the way to go.
