whose got the best?
Old Mar 7, 2008 | 08:45 PM
BIGRED97's Avatar
BIGRED97
Default whose got the best?
gotta buy a new water pump, O'Riellys or NAPA? goin for a 180 tstat while im in there. probably gonna get a reman, are they all gonna be the same?
and what are some problems i might run into. i have read through and printed out the instructions of the merry xmas thread. Thanks!
Old Mar 7, 2008 | 09:41 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: whose got the best?
I just bought a duralast from autozone tonight for preventative maintenance.
64.99 for a brand new water pump with a limited lifetime warranty, no core, not a reman. if you're changing the pump, think about doing the timing chain too, it's only about 4 more bolts.
Old Mar 7, 2008 | 10:39 PM
dhvaughan's Avatar
dhvaughan
+1 on get a new one, not a reman. i'm all for a reman in a cast iron body, but i don't like the idea of a reman in an aluminum body.
also +1 on replace your timing chain/sprocket and front seal while you're that close. if you don't there is a likelyhood you might end up with a coolant leak at the timing cover. its a sort of stupid design where coolant flows through timing cover.
https://dodgeforum.com/m_735291/tm.htm
Old Mar 7, 2008 | 11:21 PM
BIGRED97's Avatar
BIGRED97
yeah thats what i thought, im thinking i should be able to get this done in a single afternoon. is that reasonable? hopefully i can afford a new chain and new water pump, i guess that means new timing chain gasket as well.
Old Mar 8, 2008 | 08:50 AM
dhvaughan's Avatar
dhvaughan
be sure and replace the small water pump bypass hose.
also note the small o-ring that goes on the heater hose water pipe. it should be in the wp kit.
timing gasket kit comes with the big gasket and the front crank seal.
you will need a harmonic balance puller and a large socket and air gun, or breaker bar and a way to hold the engine from turning.
length of the job can really vary based upon how well (or not well) things go, as well as how experienced, and fast of a mechanic you are. troubles can occur getting the damn fan off [:@], broken bolts in t-stat housing. i'm very slow and deliberate and probably could not get it done in one afternoon. it would take me a whole day.
water pump (new, not rebuild) $63
t-stat $10
t-stat gasket $1
bypass hose $10
antifreeze, 2 gal $16
timing set Cloyes C-3072, $50
timing gasket kit, felpro $18
1 1/4 socket $6 - might can borrow.
harmonic balance puller - borrow from az or advance.
Old Mar 8, 2008 | 09:19 AM
aim4squirrels
oh, one last thing,
IDK if this matters but some of the older Rams have a WP pulley that is bolted on with 4 bolts in a square pattern, while mine was pressed on. The autozone webpage only showed the pressed on kind, and stated that is is a direct replacement for the bolted pulleys, but I would double check with somoebody to be sure if you have a bolt on style pulley.
Old Mar 8, 2008 | 11:14 AM
jperkins812's Avatar
jperkins812
Advance is the same way with only offering the press on pulley with new pumps, it won't make a difference. The new one that the part stores offer are an aftermarket replacement that cuts down on having to stock two different pumps.
Old Mar 8, 2008 | 11:19 AM
BIGRED97's Avatar
BIGRED97
awesome guys! thanks. looks like im gonna have to wait a week for my next check to come in. but i will save this thread. ive done water pumps on vehicles so im not to worried about it, i just like my truck alot more than i did my other car. so i wanted to make sure i get it done right!
