OIL PUMP!!!!! #@!$@$@@$!@$!@$$
Old Mar 11, 2008 | 09:03 PM
rabbler's Avatar
rabbler
Default RE: OIL PUMP!!!!! #@!$@$@@$!@$!@$$
Glad it worked out for you.
Did you just replace the rotor and not the distributor cap?
Only 2 quarts? Didn't you check the oil level before you took off the pan?
Or am I missing something here? [8D]
Old Mar 11, 2008 | 09:32 PM
TheForce55555's Avatar
TheForce55555
2 quarts?.............do you have a dipstick?
Old Mar 12, 2008 | 09:18 PM
mcsd913's Avatar
mcsd913
I have one but apparently it is burning up or leaking. Anywyas found new problems. p1740- Either TCC solenoid or overdrive solenoid systems doesn't seem to be making sense. P1757- Transmission control pressure not equal to target.
Old Mar 12, 2008 | 09:34 PM
rabbler's Avatar
rabbler
P1757 is usually a governor pressure sensor and/or governor solenoid.
Are you having tranny shifting problems too?
As for oil consumption, search plenum gasket...
Old Mar 12, 2008 | 09:37 PM
mcsd913's Avatar
mcsd913
yeah shifting started today....Oil is fine now. I think i just let it get to low. Any idea on what to replace?
Old Mar 12, 2008 | 09:43 PM
rabbler's Avatar
rabbler
Did you read above post?
