Anyone running larger injectors have fuel sync issues?
Iv been having a tough time setting fuel sync without a scaner after putting in larger injectors. I had fuel sync set right before the fire, but I have to retard it like crazy or it backfires horribly. I dont have access to a scanner to help. Any ideas?
Sync signal doesn't really have anything to do with the actual injectors.
It more about cam and crank sensor correlation and distributor indexing.
set your crank on TDC compression cyl #1
mark your distributor housing on the position of #1 plug wire terminal.
Pop off the dist cap and rotate until the rotor is pointing at or just past the mark you made.
That should get you pretty close.
Maybe your a tooth off on the distributor?
Turn the balancer to the v8 mark, then back probe the cam sensor. With the ignition on, rotate the dist. until it swithes between 0 and 5 volts. Try to get as close to the point that it switches as you can. The v8 mark is somewhere 15-20* past tdc. That will get you close, but you should take it somewher that has a scanner afterwards. You're probably going to want a tune to go with those injectors. What was the rating at 49psi?
ORIGINAL: rabbler
untill you get it on a scanner , be like pissing in the wind... I see where autozone or any parts store sells those scanners some can do just about any thing..but seem you been having this issue for a long time if i rember correct..
Trending Topics
ORIGINAL: padodgeram
