CATALYTIC CONVERTER SIZE
Old Mar 11, 2008 | 05:29 PM
mcss8541's Avatar
mcss8541
Default CATALYTIC CONVERTER SIZE
HEY EVERYONE, I RECENTLY GOT A BRAND NEW STOCK UNIVERSAL TYPE CATALYTIC CONVERTER FOR FREE. MY QUESTION IS CAN I RUN IT ON MY TRUCK (SEE SIG BELOW FOR SPECS)? IT BASICALLY THE SAME SIZE EXCEPT IT DOESN'T HAVE THE 2 INLET PIPES AND 1 EXIT PIPE, T'S A 3 IN SINGLE IN AND OUT. I PLAN ON EVENTUALLY RUNNING HEADERS AND AN OFF ROAD Y-PIPE FROM JEGS HOWEVER UNTIL THAT TIME I HAVE AN ADAPTER THAT WILL CONNECT THE 2 PIPES FROM THE EXHAUST MANIFOLD INTO (1) 3 INCH WHICH MAKE IT ABLE TO CONNECT TO THE CONVERTER. ALSO HAVE THE O2 SENSOR BUNG HOLES FOR THE NEW ADAPTER. CAN ANYONE FORE SE ANY PROBLEMS WITH THIS SETUP BEFORE I INSTALL IT?
Old Mar 11, 2008 | 08:26 PM
rabbler's Avatar
rabbler
Default RE: CATALYTIC CONVERTER SIZE
It's kinda big but as long as you can get adapters to make it fit I don't see why it won't work.
Old Mar 11, 2008 | 10:22 PM
98DodgeRam1500's Avatar
98DodgeRam1500
as long as its rated for your engine, sure.
thats what munro was going to do for me. I also heard that you might get a CEL from it. Not sure.
