CAMSHAFT SENSOR LOCATION????????
Old Aug 10, 2015 | 10:33 AM
Moparite's Avatar
Moparite
P0505 Idle Air Control Motor Circuits. IAC (Idle Air Control) System Malfunction
How dose it idle? The iac may be on it's way out.
As far as the cylinder #5 misfire CEL this occurs anytime. Like now the light has been off for a few days but out of the blue after i start the engine it will have a miss as though someone took the spk plug wire off just that cyclinder.
When was the last time you replaced the cap/rotor(brass inserts only) wires/plugs?
