Installing
Old Mar 11, 2008 | 07:47 PM
BackWoodz4x4's Avatar
BackWoodz4x4
Default Installing
Once I get back home this weekend im going to go pick up the edelbrock 14x3 round air cleaner and install it...does anyone have any pics or tips on how to install it?
Old Mar 11, 2008 | 08:31 PM
White Ram's Avatar
White Ram
Default RE: Installing
Check the DIY link at the top of the page
Old Mar 12, 2008 | 12:30 AM
motorbrreath's Avatar
motorbrreath
its really easy man. what i did was take the tb off, and put it on my bench with the air cleaner. and used that to guestimate where my s bolt needed to be. you gotta bend that bolt so it will hold the air cleaner on. other than that, really straight forward install.
Old Mar 13, 2008 | 06:55 PM
Gene563's Avatar
Gene563
+1 on the DIY thread. It shows the specs on the bolt you need to make. It's a 3/4 inch offset. I used a couple nuts to hold it in a vise( so not to mar the threads )and hammered it over, flipped it over and did the same on the other end. Once it was cut to length, unscrew the nut to straighten out the cut threads. I also used a nut as a locknut on the TB.
Your bolt would have to be longer than the picture here...I used a 2 inch filter, not the 3 inch.
[IMG]local://upfiles/82640/59233311C37E4AF4850DAB6FC40C296A.jpg[/IMG]
[IMG]local://upfiles/82640/E77AAAEF60CB43EF9AA62CDA5107A397.jpg[/IMG]
Old Mar 13, 2008 | 08:35 PM
1BigRamaniac's Avatar
1BigRamaniac
You do not need to take your TB off to this.
Gene563: So what you are saying is you had your nuts in a vise?!
Old Mar 14, 2008 | 03:33 AM
Racinfan83's Avatar
Racinfan83
I did mine a while back, but I took it off and put the stock one back on with the K&N drop in filter. The 14" round looked cool - but was too noisy for me. I had the 3" K&N round on mine.....
It's amazing how quiet the truck is once again with the stock one. I never got any fuel mileage gain out of it either......
Old Mar 14, 2008 | 08:18 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: 1BigRamaniac
f'n awesome!
