does transfer case part of atf system
Old Mar 11, 2008 | 09:31 PM
pipeking's Avatar
pipeking
Default does transfer case part of atf system
does the tranfer case use atf,or gear oil.is it part of the auto trans oil system.
Old Mar 11, 2008 | 09:38 PM
TheForce55555's Avatar
TheForce55555
Default RE: does transfer case part of atf system
You have to physically add ATF to the transfer case, DO NOT USE GEAR OIL OF ANY SORT ONLY ATF
The tranny and transfer case aresealed off from each other
I use ATF +4 in my transfer case just because thats what I put in my tranny.......so it makes like a little easier not having 2 different kinds of ATF on stock
Old Mar 11, 2008 | 09:45 PM
pipeking's Avatar
pipeking
ok, are u shore.see i am use to haveing a standerd truck and all you do is replace the oil in the tranny and trasfer case like a differental.so on a automatic tranny,you replace the trasfercase oil like you would on a standerd but you use atf.
Old Mar 11, 2008 | 09:49 PM
dodgerules86's Avatar
dodgerules86
I am positive that on all models the transfer case oiling system is totally seperate from the transmission.
Old Mar 11, 2008 | 09:53 PM
pipeking's Avatar
pipeking
and it takes atf?
Old Mar 11, 2008 | 10:02 PM
TheForce55555
100% sure
Old Mar 11, 2008 | 10:25 PM
dodgerules86
ORIGINAL: pipeking
and it takes atf?
Yes. ATF+4.
And TheForce55555, I love the quote in your signature.
Old Mar 12, 2008 | 12:39 AM
dhvaughan's Avatar
dhvaughan
yes it takes atf+4. about 1 qt.
tip... remove the FILL plug first to make sure it will come off. then (and only then) remove the drain plug. both are 10MM hex NOT a 3/8 which will strip it out !!!!
Old Mar 12, 2008 | 12:57 AM
pipeking's Avatar
pipeking
alright,thanx,i appriciate it..
Old Mar 12, 2008 | 01:47 AM
dodgerules86
ORIGINAL: dhvaughan
That little tip... haha... yea. I was dumb (was, lol, I amuze myself sometimes) and removed the drain plug before removing the fill plug. (Mines got a 30MM bolt, not the 10MM hex) I was worried about not being able to get the fill plug out.
