drivers side wheel bearing and hub ass.
Old Mar 14, 2008 | 10:48 AM
00dodge_ram's Avatar
00dodge_ram
Default drivers side wheel bearing and hub ***.
i`m doing the wheel bearing and hub assb. tom on my 2000 ram 1500. i`m also gonna rip the u joint out and replace taht right away.... is this hard or is it fairly simple??????
Old Mar 14, 2008 | 07:48 PM
Blaydrnnnr's Avatar
Blaydrnnnr
Default RE: drivers side wheel bearing and hub ***.
well, depends....if you search on here you'll find that some have had a real bad time getting things apart.. others have found ways to get through it fairly well...I think theres a DYI at Pavementsucks.com that shows it really well.. might want to look at it then decide if your up to the task....its by no means an impossible task.. but can be tough...hubs are hard to get off...especially on older trucks... spindle nuts can be a PITA.. but not impossible. Having a good U-joint tool makes it alot easier to do yourself...and a hub puller might help..although many have gotten the hub off with out it...some creative ways.. one thing though.... if you decide to do it.. just be careful when you finally pull the axel assemby out.. you dont want to damage the axel seals...Use the search.. theres more then a few posts on it here...
Old Mar 14, 2008 | 09:53 PM
Baddnet's Avatar
Baddnet
I will even give ya link on PS site http://www.pavementsucks.com/tech/hub.php
and a hub puller is the way to go..even if you have to rent one..
Old Mar 15, 2008 | 12:05 AM
Ramsrush's Avatar
Ramsrush
I wouldn't mess with the u-joint if it's not wore out.My truck has the factory axle u's on it and it has over 400K.
Old Mar 15, 2008 | 05:11 PM
tazman6789's Avatar
tazman6789
just did that pretty much last week. had to replace the u joint, I work at a garage so ide say it was moderate on the difficult scale, if you dont have impact tools it will be much harder to do, i had an impact to take the axle nut of and and impact chisle to get the hub assembly off so its not that bad.
