Spring break project
I have been reading as much as I can but still wanting to dbl check if I got everything I need. Def. Have plenum leak but also a leak on the ground from oil? What gasket to replace? (if i do replace what should I replace if I am already in there)
I am replacing the water pump so these just seemed to make sense to do also.
heres the part list couldn't figure difference b/t 3way chain and 7way chain?
Please edit as nec. or add! All of these are from hughes engines.
Part#Part DescriptionQuantityUnit PriceSubtotal7714V8 Plenum Reinforcement Kit
Fits All 1993-2003 V8 Magnum Engines [/align][/align]$86.00$86.003205BGasket, Intake Kit W/ Bolts
1993-2003 318/360 Magnum, Contains (1) Hug3215 And (1) Hug7700 [/align][/align]$47.95$47.951839 Thermostat, 180ยบ Powerstat
Hypertech Brand Stainless Steel High Flow [/align][/align]$10.95$10.956450Chain Tensioner SB Mopar
Reduces Chain Whip, Especially In Oval Track & Road Race Applications.[/align][/align]$43.00$43.006442 Timing Chain Set, 7 Keyway (Cam)
Keyways Are In The Cam Gear. Unique & Easy To Use! [/align][/align]$112.50$112.501837 Housing,Thermostat
Thermostat Housing, Magnum Engines 3.9/5.2/5.9, 1993-2003 [/align][/align]$9.95$9.95
