leveling kit BullSh**t
Old Mar 15, 2008 | 07:04 PM
8t5gt's Avatar
8t5gt
Default leveling kit BullSh**t
omg, i hate coil springs lol i went through the same thing with my stang when i put bigger springs in it. i cant lower my axle far enough down to put the spring and spacer in there. how do you guys do it? i had a jack inbetween the frame and the axle. it dosnt move anymore. i think ill just go get the springs banded. thats the easiest.
wat have you guys done to get them in there?
im not playing the prybar game, i lost today and got my knuckle stuck between the coil spring and the seat. OUCH! F***K
Old Mar 15, 2008 | 07:13 PM
6.7cummins's Avatar
6.7cummins
Default RE: leveling kit BullSh**t
I have not done mine yet but my buddy who just did his said he used a bottle jack.
Old Mar 15, 2008 | 07:19 PM
Chopper1's Avatar
Chopper1
when you shove down on one side the other side will go up and tilt enough to get it in. I'm assuming that you have taken the sway bar loose and the shocks off. I had to grab the fender and push down with my foot. Get a buddy that has more a$$. It may be neccessary to loosen the control arm bushings to allow them to drop easier. Try the rear first. Just if you mess with the one that has the eccentric, make sure you mark it and put back in same spot. My 3" spacers were still on the mark as far as that adjustment when aligned.
Old Mar 15, 2008 | 07:42 PM
pipeking's Avatar
pipeking
hay chpper you got 3' spacers.i ve been try to get this answered on here for a while and cant everyone just goes off topic.ok,i found a kit from www.topguncustomz.comit comes with 3' spacers,1.5' spcer for the back,new shocks,and hardware thats it.no tracbar or ext bracket,and no control arms.so is this what you have;did it work without that other stuff.you can look at it if you want,just click,it 209$.i hope you see this post chopper.
Old Mar 15, 2008 | 07:59 PM
Chopper1's Avatar
Chopper1
Personally the only spacer design I have seen that looks woth a **** is the Rancho(which is red and maches the truck) and the Daystars. bottom of the page. http://www.rockymountainsusp.com/dodge4_94_01gas.htm
Old Mar 15, 2008 | 08:26 PM
pipeking's Avatar
pipeking
i guess you didnt understand the question.withyour 3' suspention lift did you have to put a longer tracbar on or the ext.braket for tracbar,and did you have to put longer control arms on.
Old Mar 15, 2008 | 08:50 PM
Chopper1's Avatar
Chopper1
No track bar change. The kit came with new lower arms for strength but the same length. Here is the original kit on mine.
http://store.summitracing.com/partde...p;autoview=sku
Old Mar 15, 2008 | 09:16 PM
pipeking's Avatar
pipeking
thanks copper i apreciate it.thats what i needed to here for 2 weeks or so.
Old Mar 15, 2008 | 11:02 PM
rabbler's Avatar
rabbler
Unbolting the trac bar will let the axle droop lower too.
Unbolting the lower control arm will allow more too but I didn't need to do this.
I'm still using the factory trac bar and mount. I was able to align it ok but the front wheels are shifted slightly to the Left side.
Old Mar 15, 2008 | 11:22 PM
pipeking's Avatar
pipeking
rabbler, is the shift to the left very noticable
