Wiring up accessories safely
Old Mar 15, 2008 | 10:05 PM
Silver_Dodge's Avatar
Silver_Dodge
Default Wiring up accessories safely
So I got to thinking today that over the course of time, i've added a variety of accessories that each needed a 12v switched power source. Fog lights, Sirius radio, trans temp gauge, air/fuel meter, and now a tach and diff temp gauge. Each install, I was careful to find a 12v switched power source that I could tap into that wasn't already being tapped into by one of my other aftermarket accessories. Problem is, I think I have now run out of places to splice into for power, and I don't really like doing that alot anyway. I think it is time to set up a dedicated accessory power block so that I don't overload something or cause an electrical fire. Having never done this before though, how would one do this? Are there any good write-ups on how to wire up a new fuse box or power block for just your accessorries so you don't have to splice into your factory wiring.
Thanks.
Old Mar 15, 2008 | 10:20 PM
rabbler's Avatar
rabbler
Default RE: Wiring up accessories safely
Do you want a dedicated line off the battery?
You could run a 12 ga wireoff of a 30 amp fuse to a relay under the dash. Then use the accessory wire from your ign switch to turn the relay on and off.
Then run your extra accessories off the relay each with their own 10 amp fuse.
Most of your add ons are pretty low amp devices except for the fog lights
I guess you could install an extra fuse box under the dash too if you like.
Old Mar 15, 2008 | 10:44 PM
pipeking's Avatar
pipeking
i would put it under the hood so your not always on yout back,or reaching where it is hard to see.my local parts store has fuse blocks and relay blocks for cheap.i wish i still had my other truck to show you how i did it (even though it was a chevy) i had 12 kc daylighters and it came out real nice.i had alot of room though.
Old Mar 15, 2008 | 11:36 PM
padodgeram's Avatar
padodgeram
http://www.painlessperformance.com/a...overBinder.pdf
download the pdf. look at page 34 , auxfuse boxwould be what you are looking for..
Old Mar 16, 2008 | 02:20 AM
Silver_Dodge
Thanks PA, that is exactly what I was looking for. Going to see if I can pick one up tomorrow (Autozone is a dealer for them). If not, Summit has the one I want.
