tire size
Old Mar 17, 2008 | 12:51 PM
98Woo2500's Avatar
98Woo2500
Default tire size
ok, i have a 98 dodge 2500, and with a 2inch suspension and 3body. If i take off the 3inch body and leave the 2 inch suspension, would 285 size tires look good on my truck?
Old Mar 17, 2008 | 02:45 PM
Aubrey's Avatar
Aubrey
Default RE: tire size
285/what?
I've seen 325's that are real short and squatty and stick half way outside thefender. They are usually on trucks with the rear glass etched and a dove tailantenna on it too. Those look retarded.
Old Mar 17, 2008 | 03:21 PM
98Woo2500's Avatar
98Woo2500
285/75/16 i pretty sure thats a little bigger that a 32inch tire.
Old Mar 17, 2008 | 03:31 PM
TheForce55555's Avatar
TheForce55555
They should look alright, even a little small just because a stock 1500 can fit 285's with minimal rubbing, A 2500 with a 2 inch lift would sit nice on some 35's, but you would most likely have to regear the axles to gain back some lost power duea larger diameter tire
Old Mar 17, 2008 | 03:35 PM
98Woo2500's Avatar
98Woo2500
right now i have 35s on my truck and i could take off the 3inch body and the tires wouldn't rub[&:]
Old Mar 17, 2008 | 04:54 PM
TheForce55555
It depends on what kind of rims you have, But I know a stock 4 wheel drive 2500 will fit 34's without a lift
Old Mar 17, 2008 | 05:25 PM
98Woo2500's Avatar
98Woo2500
so, basically if i want to 285 to look good i need to take of the 3inch body and the 2 inch suspension.
Old Mar 17, 2008 | 10:59 PM
lizardhunt's Avatar
lizardhunt
Depends...I have the 2500 quad cab with V10 and a monster of a front bumper. 285s would rub.
I put in an equalizer kit and can now run 285s.
Front end weight will play into it...I bet if the body lift came off the 285s would look good and you shouldn't have any rub.
Old Mar 17, 2008 | 11:45 PM
HammerNailKid's Avatar
HammerNailKid
I have 285/75/r16's on a 98 1500 with stock suspension and they look good and fill up the wheel well nicely. They do rub just a little bit when I have them turned all the way. plannin on a 2" leveling kit soon and then I'll prob. move up to true 33's
FYI 285's are 32.83"
Old Mar 18, 2008 | 07:53 PM
jason15557's Avatar
jason15557
99 Ram 2500
no lift but this should give you an idia
245/75 R16
285/75 R16
