Passenger Controls not working
Old Mar 20, 2008 | 11:03 PM
Slomojo's Avatar
Slomojo
Default RE: Passenger Controls not working
Junkyards always help too... 1/2 price days and I found electric fans for $15.00 a pop!
Old Mar 20, 2008 | 11:08 PM
aim4squirrels's Avatar
aim4squirrels
Check the prongs on the window switch to ensure they are making good contact.
If its working intermittantly, you've got a bad connection somewhere. With a thin screwdriver genty bend all the male prongs in the door switch module so that they are making good contact with the female receivers in the wiring harness. Also check for corrosion from moisture and clean with electric parts cleaner. and coat with a dab of dielectric grease.
Old Mar 20, 2008 | 11:09 PM
Slomojo's Avatar
Slomojo
By the way, have you checked the continuity of everything? If not, it would be a good idea if you did before you spend your money on a new switch or switch kit. For me the switch was the problem so that's how I knew what to do. Be sure that that is the problem before you spend that cash.
Old Mar 20, 2008 | 11:18 PM
kowboydmac's Avatar
kowboydmac
Found this so far:
http://www.trademotion.com/partlocat...;siteid=214583
Old Mar 20, 2008 | 11:25 PM
kowboydmac's Avatar
kowboydmac
I don't plan on touching mine until I do my door speakers. I also have to do my driver side door lock; as that was pryed and the key doesn't work.
Old Mar 21, 2008 | 01:06 AM
TIMIDONE's Avatar
TIMIDONE
SWEET that you gave above main location is just down the street from me...no shipping cost..woot...woot!
I will have try all the above this weekend, thanks all!
