Oil Pan Problem- Yall wont belive this
Old Mar 20, 2008 | 11:01 AM
turkeyhunter1962's Avatar
turkeyhunter1962
Default RE: Oil Pan Problem- Yall wont belive this
I understand the "tight funds" thing. As long as you've good oil pressure now, you'll be ok with leaving the pump alone. Just take a good look at it so if/when you decide you'd like to replace it you'll have a good idea.
Old Mar 20, 2008 | 11:10 AM
motorbrreath's Avatar
motorbrreath
ive got the other pump out of the engine ifi need that, andi have excellent pressure right now. *knocks on wood*
now off to advance to get some gasket cement, should have read the haynes manuel better before i started. ive been back 3 different times.
Old Mar 20, 2008 | 02:04 PM
turkeyhunter1962
The oil pan gasket for our Magnum engines is a re-usable rubber gasket so you should not need any gasket cement for it.
Old Mar 20, 2008 | 11:03 PM
aim4squirrels's Avatar
aim4squirrels
You might want to use a little in the corners by the rear main bearing and up front by the timing chain cover. That's where the oil pan gasket makes the 90* bends and can leak easier than anywhere else.
Oil pumps are very cheap ~$25 I just installed a Melling High volume pump. Tomorrow I'm modding the Kegger and slapping the whole thing back together.
Rear main and timing chain were both shot. My truck's right at 78,500 miles and mine was as loose as dhvaughan's in his photos from a year ago. Still not 100% sure where the coolant is or was coming from, but the oil was black, not milky or brown so I don't think I've cracked a head or anything.
Old Mar 20, 2008 | 11:34 PM
motorbrreath
aim- i had the same coolant scare. when i pulled the pan i had coolant around the edges, but oil is not milky, and couldnt see cracks or anything in the head. I just figured it was from my coolant hose not being on tight enough a couple months ago.
reinstalling the pan was not as bad as pulling it off. just used a little cement on the corners of the gasket to keep it in place while i reinstalled the pan. once the truck burnt off the tranny fluid that was spilled on it (i did a fluid/filter change as well) it has no smoke, and no leaks. almost brings a tear to my eye.
fresh oil change with some Q horsepower 10w-30 synthetic and some restore engine additive, shes purrin like a kitten.
thanks for all yalls help.
Old Mar 20, 2008 | 11:58 PM
kowboydmac's Avatar
kowboydmac
Hey motor, where do you do your work? got a garage or just the driveway?
Old Mar 22, 2008 | 08:20 PM
motorbrreath
ORIGINAL: kowboydmac
i got a shop set up in my garage. i was doin work in the driveway which sucks compared to the garage. just get some cold beer, and put some george strait on the radio and get to work.
Old Mar 22, 2008 | 08:48 PM
mikecjn's Avatar
mikecjn
Any idea yet as to what cause the hole?
I crossed the center line on the interstate years ago while changing lanes and hit a pair of pliers laying on the road. Kicked them up with the front tire right into the oil pan. Couldn't fukin believe it. Pulled over to see them sticking out the bottom of the oil pan and oil pouring out like a bastard. Wonder of maybe you did something similiar with a rock or something...
Still got them damn pliers to this day!! I was gonna tell Neon that's one way to get new tools but didn't figure he was much in the mood after the crap tranny troubles!!
Old Mar 22, 2008 | 09:41 PM
motorbrreath
hahaha that sucks man. i dont know what caused the hole, most likely a rock or somethin.
Old Mar 22, 2008 | 10:14 PM
1BigRamaniac's Avatar
1BigRamaniac
It looks like someone drilledit or drove a nail in it to me. Someone mad at you motorbreath?
