FROM GMC TO DODGE
Old Mar 19, 2008 | 08:38 PM
ALSAMP's Avatar
ALSAMP
Default FROM GMC TO DODGE
I am about to purchase a 2000 quad cab with a 5.9. i always had chevy or gmc this is my first dodge. i have a 26ft travel trailer which weighs 4000 dry, my gmc was a 91 and struggled with that load. anyone have any input about how the dodge will handle it? or just any input about the dodge would be greatly appreciated.
Old Mar 19, 2008 | 08:41 PM
Cereal Killer's Avatar
Cereal Killer
Default RE: FROM GMC TO DODGE
is it a 1500 or a 2500 you're looking at?
Old Mar 19, 2008 | 08:44 PM
ALSAMP's Avatar
ALSAMP
1500 with towing package
Old Mar 19, 2008 | 09:09 PM
Ram2K1's Avatar
Ram2K1
How many miles?
If you search here, you will find that the majority of the 46RE auto trannies are garbage and end up having to be rebuilt. I think the average is between 100-120K, which isn't really THAT bad I guess... I would say make sure it's serviced and get a better than stock tranny cooler and pull it til it goes... As far as the weight, it shouldn't be too bad. Check your engine to see if you have a plenum leak, too. Do a search on here for "death flash" and you'll see what I mean... Welcome
Old Mar 19, 2008 | 09:13 PM
Cereal Killer
You said the trailer was 4,000lbs dry. What all do you intend to pull with it? And how often?
Old Mar 19, 2008 | 09:28 PM
jasonw's Avatar
jasonw
Site Moderator
+1 for what Ram2K1 said above.
You're looking at a maximum rated trailer weight of around 7100-7500 lbs with a 5.9, depending on if you have a 4x4 or 4x2. The 4x2 is rated at 7500, the 4x4 at 7150. So, if your pickup is in near tip-top shape mechanically, you should be fine. Just take it easy on that transmission.
Old Mar 19, 2008 | 09:31 PM
rabbler's Avatar
rabbler
I think he means without any water or supplies onboard.
I'm pretty sure its a camper trailer.
If it has a stock tire size it would be marginal. Over size tires will probably leave you wanting for lower axle gears.
See if you can find out what ratio it currently has. 3:55 is most common but some truckshave theoptional 3:92 or 4:11. the lower gears will definitely make towing easier even with stock tires
Old Mar 19, 2008 | 09:57 PM
ALSAMP's Avatar
ALSAMP
the truck has 82000 on it . what do you mean about a "death flash"
Old Mar 19, 2008 | 10:00 PM
jasonw's Avatar
jasonw
Site Moderator
Dodge dealers have been known to "update" the computer... reflash it with a new/updated program. The "update" kills the performance on our trucks.
Old Mar 19, 2008 | 10:02 PM
ALSAMP's Avatar
ALSAMP
if the plenum is leaking how much is that repair?
