rebuilding my truck
Old Mar 21, 2008 | 07:12 AM
fivenine ram's Avatar
fivenine ram
Default rebuilding my truck
sellin my truck aint happenin just because nobody wants to buy it and rebuild it and i dont really wanna sell it so my only other option is to fix it i know it needs an alternator oil pump and i think a cam i was just wonderin if this would work
http://cgi.ebay.com/ebaymotors/EDELB...em110234350318
and i caint find an oil pump onine any help is appriciated
Old Mar 21, 2008 | 07:30 AM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: rebuilding my truck
I dont think that cam will work, the older 318's had a lobe on the cam to drive the fuel pump I belive, and there may be other changes as well.
Here is what I would get: http://cgi.ebay.com/ebaymotors/93-03...spagenameZWDVW
That one is for a 360, contact brian and see if he can get you a kit for a 318. I ordered from them to build my 350 and they were VERY helpful, and I got it the very next day.
Old Mar 21, 2008 | 07:47 AM
fivenine ram
ive got a 360 in mine but i found a junkyard motor for 600 so if i was gunna spend that kinda money id go that route but the prob is its gunna be hard gettin the moeny thats why i was tryin to just replace the oil pump cam and alternator
Old Mar 21, 2008 | 03:54 PM
556fmj's Avatar
556fmj
the "LA" cam is for the older non-magnum small block chrysler. You need a "magnum" cam. It's a hydralic roller, and it's more efficent, however it's more expensive too. check out www.hughesengines.com for everything you need for your magnum. FYI, normally you can reuse the roller lifters on new cams, if they are in good shape, but if you suspect yours isn't, you'll need those too, and they are not cheap either. If it's bad enough off, you can still get decent deals on entire used engines, or long blocks just be wary of cracked heads.
