FASTMAN TB Dilemma!!!!
Old Mar 22, 2008 | 01:13 AM
HammerNailKid's Avatar
HammerNailKid
Default FASTMAN TB Dilemma!!!!
OK guys,
I know a ton of you have fastman tb's on your trucks. I just put mine on late last night along with a new round mopar air cleaner. Cranked it up and when I hit the gas my rpms jumped to 2000 and stuck there. Any ideas???? Sounds like TB is stuck open, but i dont really have a clue.
Thanks,
Old Mar 22, 2008 | 02:17 AM
Ramman18's Avatar
Ramman18
Default RE: FASTMAN TB Dilemma!!!!
My guess is the throttle cable is sticking. Check all the clips that attach it for binding. Maybe IAC motor is shot? Gotta be something right there on the TB since it worked before, right?
Old Mar 22, 2008 | 03:37 AM
jasonw's Avatar
jasonw
Site Moderator
Make sure the cables didn't get caught on each other or on something when you were reinstalling the TB. I just put mine on tonight, and the TV cable tried to get caught on the air tube from my CAI. Moved the routing of the tube slightly, and everything was fine.
EDIT: By the way, I have only comment on the pickup after the Fastman TB install...
Wow.
Old Mar 22, 2008 | 11:48 AM
HammerNailKid
Thanks,
I'm getting ready to go check it out now. I'll let you know what the problem was. I'm ready to test this thing out!!!!
Old Mar 22, 2008 | 12:00 PM
Silver_Dodge's Avatar
Silver_Dodge
Here's a picture of how the cables should run. Make sure the throttle cable is going under the cam as shown.
[IMG]local://upfiles/9095/237F6E6F65A946369163382861EBA65C.jpg[/IMG]
Old Mar 22, 2008 | 01:04 PM
HammerNailKid
UPDATE......Problem solved
Not sure there actually was a problem other than we (the truck and I) were just tired since I didnt finish the install until 1am. Anyway, I'm guessin the pcm was just getting used to it. Checked everything this morning, including the cables, and it's runnin like a charm. The response is awesome. And, like everybody else says, I can't wait until the pcm fully adjusts!!!
Thanks again for all the input,
Old Mar 22, 2008 | 01:19 PM
levikx184's Avatar
levikx184
okay so I am wondering what a Fastman TB is actually? I have been wondering what these things do for a while now so I guess I'll ask now... what is it?
Old Mar 22, 2008 | 01:37 PM
turkeyhunter1962's Avatar
turkeyhunter1962
Dan Arkand "aka The Fastman" takes stock throttle bodies and uses a computer controlled milling machine to upgrade them. He removes excess aluminum from areas where turbulence is caused and cuts the throttle bores to either 50 or 53 mm in size. Stock throttle bodies are have a tapered throttle bore from top to bottom. He also machines new throttle plates and new throttle plate brackets and screws. I am not sure of the exact numbers, but his throttle bodies have a much better air flow than a stock throttle body.
Some people have mentioned that they could do the same thing with a hand grinder, but a person could never match the precision that his computer controlled milling machine does.
Old Mar 22, 2008 | 03:00 PM
rabbler's Avatar
rabbler
ORIGINAL: turkeyhunter1962
Hand grinder???
Man thats a scary thought...
Old Mar 22, 2008 | 04:44 PM
BadHab1t's Avatar
BadHab1t
yeah really scary .......this fastman tb is great plain and simple i love mine and will love it more once the plenum is fixed soon i promise its great that lots of us are doin similar mods to date or even same mods lots of plenums and tbs goin into our trucks right now its great............j ps hey siver thtas what i forgot to do and wondered y my gas pedal wouldnt work dumb mistake but got it right .........
