M P G
Old Mar 31, 2008 | 12:42 AM
jasonw's Avatar
jasonw
Site Moderator
Default RE: M P G
Mine were all 32 except for the driver's side front tire, it was 34 for some reason. I upped them all to 36 and two fill ups later noticed a consistent 0.5 to 1 mpg increase. And that was right before the temps started increasing, so I don't think that was influencing it much yet.
The ride was a tad stiffer over bumps, pot holes, etc. but no, no jitters.
I don't know if I'd do 45, I am pretty sure (if I remember correctly) thats what my tires say is the maximum pressure they can take. Also, you put too much in, your tires will wear weirdly.
Old Mar 31, 2008 | 02:47 AM
Ramman18's Avatar
Ramman18
Default RE: M P G
First, check what's repairable before adding aftermarket parts. These trucks will get between 11-17 in the city in stock form. Winter gas drops it a little, long idle times, stop/start, etc.
1. Make sure the plenum isn't leaking.
2. change all fluids in drive line
3. Run MCCC or Seafoam or both
4. Do a full tune-up
5. Oil change
6. Try really good gas like Shell or Chevron with cleaners
Then take it for a good hard trip like 100+ miles. If nothing changes, you've got either a lemon or a huge foot. Probably not the former. You might also have the deathflash. That will drop mileage 1-2. Check for stickers saying "authorized software upgrade" on the pcm or radiator support. If so, get a Hypertech or Superchips. Gained me instant 1-3mpg. But seriously, a good tune-up and new oils help big time. Good luck.
Old Mar 31, 2008 | 08:54 AM
securtis12's Avatar
securtis12
Default RE: M P G
I just changed my tranny with one from Dr. Evil and I do not know if it was a fluke or not but went from 13 to 16 back and forth to work. I am going to keep an eye on it but do know I dropped 300 rpms at 60.
Old Mar 31, 2008 | 09:12 AM
Baddnet's Avatar
Baddnet
Default RE: M P G
I thought MPG = My Petro Guzzler..
Old Apr 1, 2008 | 04:47 AM
HankL's Avatar
HankL
Default RE: M P G
it is worth figuring out the question:
if more air in my tires gives me more MPG at today's high fuel prices
how many miles less can my tires last than the typical 40,000 miles
and I still come out ahead saving money overall?
it is more accurate to ask the question:
how can I lower my cost per mile driven
than
how can I raise my MPG?
Old Apr 1, 2008 | 06:49 AM
98DodgeRam1500's Avatar
98DodgeRam1500
Default RE: M P G
I was getting 10.5-10.9 MPG until I had my catalytic converter replaced along with the two O2 sensors. now I get 12.6 - 12.9 (city). I also had my transmission rebuilt and getting TC lock up at 40-42mpg in O/D.I am also in a all stock truck with the optional tire size of 265/75/16. 5.9L, 4x4, QC.
9MPG is a sign of a engine issue. Start with what you can afford, a tune up (plug, wires, and distributor cap), and air filter. I have researched CAI and found that the gains are very minimal if negative (driving style has a lot to do with it), but in general they do nothing. If you have a higher cfm flowing exhaust then a CAI will help it breathe, and a WOT gain will be found with the CAI.
Anyhow, keep your oil changed, use good stuff, and don't use FRAM oil filters, and don't get the gimmick add-ons. Like TB Spacers, oil aditives, fuel aditives, that resistor found on eBay, or anything that just seems to good to be true.
Yes, the RAM is a big fat road hog and requires constant care at because of their age and how parts just wear out.
Keep your tires up on pressure, tune it up, drive like a ganny, and make sure its 100% in mechanical shape.
Best of luck.
Old Apr 1, 2008 | 12:58 PM
1BigRamaniac's Avatar
1BigRamaniac
Default RE: M P G
I run 42 psi in my 265's
I drive 55. If you can't don't whine about mpg.
You don't want a loud exhaust for you daily driver.
Old Apr 1, 2008 | 01:10 PM
Cereal Killer's Avatar
Cereal Killer
Default RE: M P G
ORIGINAL: 1BigRamaniac
I drive 55.
Just out of curiosity... You're old aren't you?
Old Apr 1, 2008 | 03:56 PM
Baddnet's Avatar
Baddnet
Default RE: M P G
ORIGINAL: Cereal Killer
I drive 55.
hey I'm old LOL..but I love the sound of a sweet V8.. wife gives me crap cause I turn down the stereo so I can hear the truck
Old Apr 1, 2008 | 04:06 PM
Dominator7's Avatar
Dominator7
Default RE: M P G
I definitely think that the higher the air pressure the better the fuel economy-I have some Dueller A/T Revos and I have them at 60 psi they are rated for 80 lbs at max and I drive on the highway often and average 15 to 16 mpg-thats pretty good for a truck thats got 180,000 miles on it!
