tried everything i can think of
Old Mar 23, 2008 | 02:51 AM
dodgeforlife15's Avatar
dodgeforlife15
Default RE: tried everything i can think of
i had a misfire in cylinder 5. mine was throwing codes for both a random misfire and #5. i replaced the ignition coil and the dist cap and it solved the problem.
Old Mar 23, 2008 | 11:09 AM
outatime's Avatar
outatime
When you replaced the wires how did you route them? There is a tsb that has different routing than before because of misfires .Pay close attention to # 4&8 and 5&7 then cannot touch at all and should be at least one inch from each other from cap all the way to plug.Have one in shop right now i just did it to and fixed problem.Now if If I could just get the damm thing to quit running rich It would be complete.If you need exact diagrams of wire routing let me know
Old Mar 24, 2008 | 08:18 PM
BIGRED97's Avatar
BIGRED97
well i was looking at it all again today. and took it too work. the mechanics were saying its not a cat issue. however is was noticing that there is a hiss/squel/chirp type that sounds like it is coming from the power steering or water pump, whenever the miss in idle hits. i dunno if that important news or not.
OUTATIME- we followed the wiring diagrams that are posted under the DIY tab up top of this forum. i dunno if thats the one you were talking about or not.
Old Mar 24, 2008 | 09:04 PM
turkeyhunter1962's Avatar
turkeyhunter1962
Check the electrical connections for the Crankshaft Position Sensor (CPS) and the Cam Position Sensor, which comes out of the distributor. I had a random misfire that played heck with my truck until I pulled those two connections apart, cleaned the corrosion as good as I could, put di-electric grease on the connection, and re-connected them. You should also do this to the connection to the coil. It's a cheap fix, less than $2 and it worked for me.
Good luck.
