Old Aug 6, 2015, 02:56 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical System
Print Wikipost
reset check engine light
Old Mar 23, 2008 | 08:05 PM
Ramsrush's Avatar
Ramsrush
Default RE: reset check engine light
Pull the #4 plug out and see what it looks like.
Old Mar 23, 2008 | 08:12 PM
owens2500's Avatar
owens2500
its a dark brownish color??
Old Mar 23, 2008 | 08:26 PM
Ramsrush's Avatar
Ramsrush
That's normal. Is the electrode wore down any?
Old Mar 23, 2008 | 08:29 PM
owens2500's Avatar
owens2500
alittle not bad they dont look like new plugs tho
Old Mar 23, 2008 | 08:35 PM
Ramsrush's Avatar
Ramsrush
I'd start with changing plugs and see if that helps.I use autolites.
Old Mar 23, 2008 | 08:36 PM
owens2500's Avatar
owens2500
k ill change them tomar and let ya kno thanks for the help
Old Apr 3, 2013 | 05:05 PM
OlafAndree's Avatar
OlafAndree
Default 97 dodge ram van b2500 360 cid ,5.9l
hello i gott some problems ,i gott code 12 and code 44 ,anyone maybe knows whats wrong and how to clear check engine light
Old Apr 3, 2013 | 05:13 PM
zman17's Avatar
zman17
Retired Moderator - RIP
To reset the PCM, just remove the negative battery cable, turn on headlights for a minute or so, turn headlights off and reconnect battery terminal. As far as the 44 code goes, you might want to replace the sensor under the battery, or at least check the wiring going to it for acid corrosion. The 12 code is nothing, so don't worry about that. Take a look at this. http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm Whether you decide to clean the contacts on that sensor or just replace it, remove the negative battery cable before doing so.
