Anyone have any Special Tips before I start my Header Install??
Old Mar 25, 2008 | 09:35 PM
blkbaretta's Avatar
blkbaretta
Default RE: Anyone have any Special Tips before I start my Header Install??
ORIGINAL: rabbler
Wipe everything down with Alcohol or brake clean before you start it the first time when your all done.
Otherwise you'll have stains and fingerprints that won't ever go away.
If you have access to a torch keep it handy. A little heat really helps stubborn bolts.
Good luck
Thanks man. That would be bad to have nice, new, ceramic coated headers with nasty fingerprints all over them. I'll be sure and clean them up nice before I start it up. I wish I had a torch, but I don't. I'll have to come up with another way to heat them up if I'm having any trouble.
ORIGINAL: Slomojo
Go to Harbor Freight and get yourself some swivel neck ratcheting SAE and Metric Wrenches if you don't already have some. They are $30.00 per set but will save you hours when bending over your entire front end doing the job on your keens when you have to install the headers. This is a must.
Try to be sure the header bolts aren't too short. Locking header bolts are probably longer than normal ARP header bolts. This will make the install go by quicker as well... I got the cheap ARP header bolts and they worked out fine but I found the install took more time then it should've and I wasn't able to install any of the washers that came with the bolts since they were so short.
And last but not least, Save those old bolts. Use them when installing your new bolts so that your headers will hang on them and not go anywhere till your other bolts are firmly secure and your ready to swap em out for the new ones.
Yeah, thanks man. I'm actually borrowing some swivel and universal wrenches from one of my friends so hopefully that will help out. I've got the header bolts that came with the headers and they seem like they should work. I'll have to wait until I get the old ones off first and see how it looks. Thanks again.
ORIGINAL: 1BigRamaniac
Don't throw away your old manifolds. Clean them up and keep them.
Oh no worries man, I'll keep them just in case.
ORIGINAL: Mohawk
locking header bolts, or thread locker. Make sure they dont come loose but dont over tighten like Silver Ram said. Dont want to crush any gaskets and have them not seal properly, ull have a great smell in your cab if you do.
Yeah, I'm thinkin about getting some thread lock, but we'll see. I may just keep a sharp eye on them and make sure they don't come loose. I definitely don't want any bad smells up in the cab. Thanks.
Old Mar 26, 2008 | 03:57 PM
Silver_Dodge's Avatar
Silver_Dodge
For a little extra room installing, removing the valve covers helps. Not necessary, but helps a little. That's about all the tips I can think of.
Old Mar 26, 2008 | 06:07 PM
aim4squirrels's Avatar
aim4squirrels
If you can't reach the bolts on driver's side, try pulling the engine, that should give you the room you need....
Totally kidding...
Old Mar 26, 2008 | 11:22 PM
blkbaretta's Avatar
blkbaretta
ORIGINAL: Silver_Dodge
Thanks a lot man. You've really helped out a lot and given me some good ideas. I really appreciate it; I can use all of the advice I can get.
Old Mar 26, 2008 | 11:25 PM
blkbaretta's Avatar
blkbaretta
ORIGINAL: aim4squirrels
Totally kidding...
Ha ha, yeah i wish I could do that. It would be easy, but I get the feeling that pulling the engine would be harder than laying across the front of the truck to get to the back few bolts. We'll see though.....
Old Apr 15, 2008 | 12:56 PM
tj1320's Avatar
tj1320
ORIGINAL: blkbaretta
Totally kidding...
I know this is probably too late for you but another GREAT tool for laying across the front of the truck is carpenter's knee pads. You know, the kind that tile and flooring layers wear. I used them when I replaced my plugs, wires, cap, and rotor a couple weeks ago and theyprevented a hell of a lot of pain in my knees.
