WOT a/f timing?
Old Mar 27, 2008 | 11:14 AM
DGarmon's Avatar
DGarmon
Default WOT a/f timing?
Good Morning, I was just wondering if anyone knew what the Stock WOT a/f timing is for a 2001 Ram Quad cab 5.2 is? I recently purchased an SCT programmer and they are needing the Stock WOT a/f timing so they change make a few changes to a few things. If not is there away to find out. Thanks
Old Mar 27, 2008 | 03:07 PM
IndyRamMan's Avatar
IndyRamMan
Default RE: WOT a/f timing?
ratio?
Old Mar 27, 2008 | 03:27 PM
DGarmon's Avatar
DGarmon
Are you asking for my Ratio and asking if that is what I'm needing? The SCT dealer which I bought my SCT programmer is trying to change the timing at idle but needs to know what the Stock Timing is so he can change it, which I'm not sure what it is. The main reason for this is because when I do WOT there is an 1 to 2 second delay before it kits in and he said he should be able to fix it if the WOT a/f timing was changed a little.
Thanks
Derek
Old Mar 27, 2008 | 03:28 PM
mopowar's Avatar
mopowar
On mine, wot fuel was 13ms. Our pcm's operate with a narrowband o2 sensor, so you they don't really use a/f ratio perse. At wot, you tune the spray (injector pulsewidth). Timing is based on a set ofmaps that use several diferent variables, i.e. RPM, IAT, ECT, calculated load, etc., to determine what the timing advance is at any given moment. Stock, my wot timing was in the 25* advanced range after ~2k rpm's. Who did you buy the SCT from?. If your pcm # is in the software (which it should be) then they can pull all the stock maps up and look at them. I'll send you a pm with an email address for a guy who will write you a tune.
Old Mar 27, 2008 | 03:38 PM
mopowar's Avatar
mopowar
ORIGINAL: DGarmon
Thanks
Derek
It's a problem with the fuel timer not writing correctly. I was told that SCT would have a look at it after the Hemi craze calmed down. Apparently they just came out with the 5.7/6.1 software and are working the kinks out of that. I have another box to use in the mean time. What is the p/n on your box?
Old Mar 27, 2008 | 03:48 PM
DGarmon's Avatar
DGarmon
I bought my SCT from Sean " hemifever" and he has to be the best support person I have ever dealt with. He was awesome to buy from and the support is TOP Notch and I've been really enjoying the programmer ,1000 times better then my Hypertech I was using. The thing is for some reason SCT locked the part with access the Stock timing table for the WOT timing and he needs this to make the change to14 degree's timing and he can change it if he has the Stock data. I asked him the other day and this is what he's asking for.
Thanks
Derek.
Old Mar 27, 2008 | 03:52 PM
DGarmon's Avatar
DGarmon
Here is my P/N # 56028544AB
Old Mar 27, 2008 | 03:58 PM
mopowar's Avatar
mopowar
I agree, Sean is top notch all of the way. He helped me out alot. If he has not changed your timing, then it should still be what it was stock? If so, you could get a cheap scanner and record what the timing is at different rpm intervals. Another thing you could do is get him to give you the part # for a box that he has tuned without issue, and try to find one used.I got one for $50. If you go that route, you will have to get someone to write your vin into it.
Old Mar 27, 2008 | 04:19 PM
DGarmon's Avatar
DGarmon
Do you what kind and\or brand I would need to get if I decide to go the scanner route?
Old Mar 27, 2008 | 05:43 PM
mopowar's Avatar
mopowar
I bought an Equus Innova off of ebay for around $100 IIRC. Just make sure what you buy will comm w/ ISO 9141 and you'll be alright
