Help Choosing Heads/Cam
Old Mar 28, 2008 | 06:18 PM
mopowar's Avatar
mopowar
Default RE: Help Choosing Heads/Cam
Your stock injectors are supposed to flow 23.2 lbs/hr. The Accels I run deliver ~24.5 at our pressure. The stock injectors are probably under driven a bit. Since swapping injectors is something that you can do relatively easy atany time, It might be better to take that money and put it towardbuying the stuff neccessary to tune what you end up with. If it turns out that you're over-driving the stock injectors then you can buy larger ones when you figure that out.
Old Mar 28, 2008 | 10:22 PM
tj1320's Avatar
tj1320
Sounds good. Thanks for the help.[sm=smiley20.gif]
