CEL HMMM....UPDATE
Old Mar 29, 2008 | 05:59 PM
davmelrach's Avatar
davmelrach
Default CEL HMMM....UPDATE
Well... here is a good one for somebody. I was pulling from stop sign today and suddenly my truck was bogging down. Well it continue to have no power for a couple of miles until I reached home. The truck stalled out on me in the driveway. I came back out a few minutes later and no problem other than the CEL came on. So I take it to Auto Zone to get the code checked and they tell me it a Speed Output Sensor. Well they turn the CEL off and before I get out of the lot it throws it again. Strange thing is the truck is running fine now. Anybody got a clue what the SOS sensor is or where its located. I'm lost on this one.
1988 4x4 Longbox
5.2L 80000 miles
Old Mar 29, 2008 | 06:54 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: CEL HMMM....
There are 2 speed sensors, one on the Tranny, and one in the rear differential.
The code should tell you which you need to change, search the forum here of a list of codes and match that number.
Old Mar 29, 2008 | 07:28 PM
davmelrach's Avatar
davmelrach
Hey I appreciate that.... One more question. I ran into this problem on another vehicle I had when I replaced the sensor with a non OEM part IE., Auto Zone aftermarket, I could not clear the code. Have any of you guys had any luck replacing the sensors with non OEM parts.
Also, does that sound like a problem that speed sensor going bad would cause, loss of power stalling but only temporarily?
Old Mar 29, 2008 | 07:38 PM
rabbler's Avatar
rabbler
ORIGINAL: davmelrach
1988 4x4 Longbox
5.2L 80000 miles
Is your truck an '88 or is that a typo?
Old Mar 29, 2008 | 08:01 PM
davmelrach's Avatar
davmelrach
Default RE: CEL HMMM....UPDATE
Well it was my Speed sensor... And if anyone else has the same problem, I found the sensor at Advance for $16.98. It was easy to put in. The sensor is located at the rear of the tranny on the driver side, just a little note, get ready for some tranny fluid to spill out cause it does when you take this sensor out. I was a little worried about a non-OEM part not tripping off the CEL but after taking off the negative battery cable and reseting the computer it was gone for good and the truck runs great!
1998 4x4 Longbox
5.2L Auto 80000
Old Mar 30, 2008 | 08:33 PM
davmelrach's Avatar
davmelrach
BTW there is a wealth of info on here about sensors by utilizing the searches.
Old Mar 30, 2008 | 08:46 PM
Ramsrush's Avatar
Ramsrush
BTW there is a wealth of info on here aboutnearly everything by utilizing the searches.
