heatercore replacement?
Old Mar 31, 2008 | 12:35 AM
Sinister's Avatar
Sinister
Default heatercore replacement?
Im guessing since i'm smelling antifreeze through the vent when I'm running my heater, the heatercore must be on its way out.. especially since i dont have any visible leaks anywhere under the hood..
has anyone done a change.. and if so.. approximately how long does it usually take since it seems that removing the dash is part of the process.
thanks
Old Mar 31, 2008 | 01:05 AM
Zeppelinrocks's Avatar
Zeppelinrocks
Default RE: heatercore replacement?
there is a diy writeup in the top of the fourm, i havnt done it personally but alot of people on here have. The writeup has lots of pictures and great detail.
Old Mar 31, 2008 | 07:48 AM
Sinister's Avatar
Sinister
Ah, there it is.. thanks..
Looks like its a Pain in the ***.
Old Mar 31, 2008 | 09:16 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: Sinister
PITA, yes. But I'd rather do that than pay a shop $800 to do it.
Old Mar 31, 2008 | 10:19 AM
davmelrach's Avatar
davmelrach
It is really not all that bad. Just dont get in a rush and do it one step at a time. It is probably a 5 on the 1-10 difficulty sale, 10 being most difficult. I was able to borrow some gauges and a vacuum pump from the parts store for the A/C other than that you wont need any special tools other than a 5 dollar fuel rail tool. BTW 800 would be a deal to get anyone to do it, I have heard of worse quotes so this is definatley a DIY.
Old Mar 31, 2008 | 10:49 AM
Unreal2k3's Avatar
Unreal2k3
Really that much? My mechanic only charged me $210 for labor when I had my heater core replaced. I had him install an aftermarket heater core from advanced auto that cost me $80-ish, only cost me $300 in all.
Old Mar 31, 2008 | 12:08 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: Unreal2k3
Why did you need the fuel rail tool? Also, I must be a total bad-***, because I can remove the clip on the fuel rail with two hands
Old Mar 31, 2008 | 12:16 PM
davmelrach's Avatar
davmelrach
Well when I had to diconnect the A/C lines from the accumulator to remove the HVAC box i had to use the disconnect tool. I guess you can "two hand" it.... good luck with that.
Old Mar 31, 2008 | 12:41 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: davmelrach
I didn't remove the A/C lines when I replaced my heater core. Boo-YAH!!! [sm=bounceybounce.gif]
Old Mar 31, 2008 | 01:08 PM
davmelrach's Avatar
davmelrach
Thats why you will be doing that job all over again real soon when your evaporator goes out. Ill let you borrow my disconnect tool when you cant "two hand it".
