RADIO
Old Apr 1, 2008 | 08:09 PM
ALSAMP's Avatar
ALSAMP
Default RADIO
I have a 2000 quad cab and the front speakers only work occaisonally, it doesnt seem like a loose wire because they dont come on when driving over bumps, they just sometimes come on but most times not. is it a bad radio or bad speakers?
Old Apr 1, 2008 | 08:31 PM
andrewallen88's Avatar
andrewallen88
Default RE: RADIO
yea my right front speaker doesnt work at all either and i was going to take the door panel off but i dont know where to start. has any one took theres off??? can somone help me thanks.
Old Apr 1, 2008 | 08:49 PM
tresvn's Avatar
tresvn
Default RE: RADIO
My right front speaker is out as well, buti havent attacked it yet. i did pull the drivers door panel it was easy there should be a screw on the top of the panel by the dash. remove that then grab the panel where it has loosened and pull firmly should just pop out dont pull too hard theres connectors and wires that you dont want to damage. after the panel is off you will see the clips still in the door pull them out and install them on the panel now just line up the clips with the holes in the door and press real hard , put the screw back in and your done. dont know if this is the "right" way but it works, as long as your not an animal about it good luck
Old Apr 1, 2008 | 10:45 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: RADIO
3 screws, 2 in grab handle, 1 by side view mirror. Then pull straight out and the clips will let go. A panel removal tool helps a bunch on the factory clips, then buy Chrysler panel replacements at the local AP store.
Old Apr 1, 2008 | 10:48 PM
hometheaterman's Avatar
hometheaterman
Default RE: RADIO
Good luck. I had my door panel off several times and the first 2 all went great. The 3rd time the pieces on the door panel that hold the clips started snapping off. I think they were weak from the other 2 times. My buddy that worked at a Dodge dealer told me this was very common and happened all the time to them. I luckily still have enough it holds my door panel tight. I think 3 broke on one side and 2 on the other or something like that. I suggest using a trim removal tool as to try to not put soo much pressure on the panel. Maybe that will bring the clips out with the panel. I don't think I used my trim tool the first time I'm not sure about the 2nd but I used it the 3rd.
Old Apr 1, 2008 | 11:04 PM
TIMIDONE's Avatar
TIMIDONE
Default RE: RADIO
Yea my front right speaker wasn't working also...so I had a simple solution...I replaced it!
But I didn't have a trim removal tools and wish I did. I broke so many clips and it just doesn't seal the same now!
Invest on it unless you want to speed the money on new clips and the pain of pulling off all the ones that stay in the door! *pliers ftl*
Also those clips aren't cheap...I mean they just a lil piece of ****ing plastic! [:'(]
Old Apr 1, 2008 | 11:05 PM
cdusthockey's Avatar
cdusthockey
Default RE: RADIO
ive had mine off a few times with the speakers only working on and off. once i put the new speakers in though ive had no problems. you are gonna break a couple clips, but i just stuck them back in the important spots and have had no problems
Old Apr 2, 2008 | 12:03 AM
hometheaterman
Default RE: RADIO
Yeah I can't comment on the stereo problem as I didn't have it and now run a amp and the components in the front and coaxials in the rear are wired directly to the Alpine amp that powers them.
I did have a problem like that in my Honda with a speaker not working turns out it was the speaker. At first I think it worked some but not often. Not positive though.
