Aftermarket Intake
Old Apr 2, 2008 | 08:45 AM
phlash_riot's Avatar
phlash_riot
Default Aftermarket Intake
I am looking for a good aftermarket intake to fit on a 5.9 hopefully made of a composite material but I doubt that is going to be avalible. But in any case looking for something with a better flow and a better look to it. anything out there along those lines. I found the M1 but have not done alot of study intoit; but not sure that i want that one right now.
Old Apr 2, 2008 | 09:46 AM
turkeyhunter1962's Avatar
turkeyhunter1962
Default RE: Aftermarket Intake
Continue searching through all of the posts here on the forum and you'll find that you have about 3 options and only 3 options for intake manifolds.
[ol][*]Stock barrel manifold - Either in stock configuration or manually modified by cutting and smoothing the runners and replacing the plenum with either a Hughes or APS billet aluminum one. I painted mine with aluminum paint, but some have went to the expense of color powdercoating theirs.[*]M1 intake[*]I believeHughes manufactures a manifold, but according to others it is no better than the M1 and a lot more expensive.[/ol]
The main power difference between the stock barrel intake and the M1 or Hughes is where your power develops in the RPM range. The barrel has lower RPM torque numbers while the M1 or Hughes have higher Horsepower but at a pretty high RPM > 2500 / 3000 RPM. Unless you're drag racing your truck, the stock barrel intake is your best option.
Old Apr 2, 2008 | 11:28 AM
IndyRamMan's Avatar
IndyRamMan
Not to get anyones hopes up, but just a little fyi, this summer I might fab a sheet metal intakethats less agressive than the m1, but moreso than the stock manifold. If it goes well Id consider making more.
Old Apr 2, 2008 | 12:15 PM
turkeyhunter1962
It sounds to me like you have entirely too much free time on your hands. If you're in my neighborhood why don't you stop by and help me swap out my 3.55 gears for 4.10's? Heck, I might even spring for us to take a little fishing trip up to this great walley lake I know of.
Old Apr 2, 2008 | 01:58 PM
IndyRamMan's Avatar
IndyRamMan
Some days I have way too much time, others there arent enough hours in a day and not enough days in a week. Its crunch time for the semester so not much gets done arround now, just a lot of typing. Summer I definately have too much time on my hands.
This summer my buddy and I are also building a toy...
You be the judge if I have too much time.
Sorry to hijack the thread.
Old Apr 2, 2008 | 10:19 PM
TIMIDONE's Avatar
TIMIDONE
Oh I wonder how far you can throw a chevy with that!
Old Apr 2, 2008 | 10:25 PM
my1500.net's Avatar
my1500.net
Not very far---- they tend to crumble at launch from the force.
Old Apr 21, 2008 | 07:53 AM
phlash_riot
Well it looks to me that i will keep the stocker. probably going to find a stocker for sale cheap some where in used condition and clean it up and most likely powder coat it red. i take it that you can basically do a port and polish job on these to increase airflow. probably just do a home polish job with a dremel on it myself and get the alluminum plennum doodad. thanks for the info
