-40F???? why
Old 04-04-2008, 10:05 PM
Bossman9784's Avatar
Bossman9784
Bossman9784 is offline
Default -40F???? why
Hey all,
I have a question about my 01 2500 5.9L ram. The overhead counsel reads -40F and does not change. It says in the owners manual that if it reads -40F see your dealer. I contacted the local dealer (small town) and they have never heard of this problem. I do live in the UP of MI, its cold, we still have a couple feet of snow, but its not that cold! Can somebody tell me whats going on with this thing and how I can fix it.
Thanks
Boss
Old 04-04-2008, 10:43 PM
Shawn86's Avatar
Shawn86
Shawn86 is offline
Default RE: -40F???? why
Yeah about all I could offer is to call another dealer. Good luck with that!
Old 04-04-2008, 11:06 PM
defiantmopar's Avatar
defiantmopar
defiantmopar is offline
I am thinking your thermister for the temperature sensor is broken or it is unplugged from the console. but if it is broken most likely it will need to be replaced. You just have to find out where they stuck the thing.But that is just my opinion.
Old 04-04-2008, 11:11 PM
Dtruck96's Avatar
Dtruck96
Dtruck96 is offline
Mine did that once and then it read OC which I thought for the longest time it was just 0 degrees celsius. Granted I was living in Fairbanks Alaska. When I checked with the dealer they said it meant Open Circuit. They said to check the plug in behind the front bumper. On mine is was a loomed wire with a clip on it. Almost looked like was going the front fog lights. It turned out my clip was bad. Check that out. Hope it helps.
Old 04-05-2008, 09:38 PM
luvmytrk's Avatar
luvmytrk
luvmytrk is offline
dont know if this will work or not but im a chrylser tech and theres been a few recalls i did on the newer durangos that the overhead would read -40degrees afterwards the instructions say to disconnect the battery for about 10 seconds.
may or may not work for your 01 ram but its worth a shot
Old 04-06-2008, 05:07 PM
rabbler's Avatar
rabbler
rabbler is offline
The ambient temp sensor is located in the center of the grill. Check the connectors and wiring harness. If you unplug the sensor and your console reads OC (open circuit) it is most likely a bad ambient sensor.
Old 04-07-2008, 09:40 PM
CowboyBob's Avatar
CowboyBob
CowboyBob is offline
I unplugged mine when I removed the hood. When I put the hood back on, I forgot to plug the sensor in. It read -40f until I plugged it back in. I never saw OC.
Quick Reply: -40F???? why
