Tran fluid on trans case/pan
Old Apr 7, 2008 | 06:22 PM
TIMIDONE's Avatar
TIMIDONE
Default Tran fluid on trans case/pan
per a very user request that I might of been thread jacking which I didn't mean to do and I am sorry if it seemed that way but:
"I did notice one thing I was hoping you guys could help me with...I noticed trans fluid on the outside of my tranny and on my tran pan....enough to cover it but not enough to drip to the payment.
I checked the oils and all is full...checked the stick and it is running clearn. Should I be worried? is this normal? Any help would be great!"
Thanks!
Old Apr 7, 2008 | 07:20 PM
rabbler's Avatar
rabbler
Default RE: Tran fluid on trans case/pan
Minor seepage is no big deal but if you want clean and shiny then fix it.
My shifter shaft seal has a slight leak but not bad enough to make me want to change it.
I'll probably fix it this summer ifI install my shift kit.
Old Apr 7, 2008 | 09:59 PM
MonteC's Avatar
MonteC
alot of the chyslers old standby transmissions leak. Even after overhaul they will start to leak.
Old Apr 8, 2008 | 01:02 PM
TIMIDONE's Avatar
TIMIDONE
Good to know I don't have to freak! Thanks!
