Tire Pressure???? '98 Ram 1500 4X4
Old Apr 10, 2008 | 01:34 AM
duckhtn's Avatar
duckhtn
Default Tire Pressure???? '98 Ram 1500 4X4
Hello all! I have a '98 Ram 1500 4X4 with the factory sized tires on it which I believe are 265x75x16. Now Dodge says to go with 35psi, but on the tires it says 80psi. Where should I have them at?? I spent way to much to wear them unevenly, so I really need to have the correct pressure in them. By looking at them with the 35psi in them, they look low and another person mentioned that the other day too. So someone that really knows the right psi to go with, PLEASE help me out here.
Thanks in advance!!
Old Apr 10, 2008 | 01:44 AM
rabbler's Avatar
rabbler
Default RE: Tire Pressure???? '98 Ram 1500 4X4
35-40 should be fine when not carrying a load.
If carrying a very heavy load you will want to increase it.
80 PSI is max pressure based on tire design.
Put those same tire on a loaded 1 ton and you'll need 80 psi to carry the load properly.
Old Apr 10, 2008 | 02:55 AM
Ramman18's Avatar
Ramman18
Ask your tire shop. Btw, stockers were 245s. Those must be E range to have 80 max.
Old Apr 10, 2008 | 12:18 PM
citygasdude's Avatar
citygasdude
When doing research for which tire I was going to get, I came across a post from someone who was buddies from a Goodyear engineer and he suggested max psi on side wall cold pressure to get the most miles out of the tires. I just bought some Goodyear Wranger Silent Armor's and the tire place put 80 psi in them which is the max cold pressure. The ride is good, so far only have put about 100 miles on them.
Old Apr 18, 2008 | 06:44 PM
duckhtn's Avatar
duckhtn
Yes, I do believe they are "E" load range tires. I wanted something a little bigger then the 245's as well as a tire that is going to last me awhile for what they cost me. Maybe I will increase the pressure and see how they ride.
Old Apr 18, 2008 | 07:27 PM
mstephen89's Avatar
mstephen89
I have 50psi in all my tires, but I do alot of towing.
