1996 Ram 1500 with Infinity system - left side speakers cut out sometimes??
Old Apr 10, 2008 | 01:36 PM
chris*tx's Avatar
chris*tx
Default 1996 Ram 1500 with Infinity system - left side speakers cut out sometimes??
Any ideas?Has anyone experienced something similar?
thanks,
Chris
Old Apr 10, 2008 | 01:41 PM
PartsChaser's Avatar
PartsChaser
Default RE: 1996 Ram 1500 with Infinity system - left side speakers cut out sometimes??
Is it your front door speakers, or in the rear? Need a little more info.
Do they cut out at any volume, or after a good high-volume romp through a few songs? Generally speaking if everything is still stock, I'd say you might have a pinched wire somewhere, or a corroded connector on the door speakers. Mine got wet once upon a time, and caused some havoc inside the doors, might have to pop the door skin to do a little investigating.. Good luck!
Old Apr 10, 2008 | 07:35 PM
mstephen89's Avatar
mstephen89
yea its either the radio or the wiring. Personally since the wiring is in a wiring harness, I would just run a new wire to that speaker. If it keeps doing it then its your radio
