What size is my sway bar?
Old Apr 10, 2008 | 11:25 PM
nateblong's Avatar
nateblong
Default What size is my sway bar?
I am going to replace my sway bar bushings and end links on my Ram. The end link bushings are severly cracked up. So I measured the sway bar using a cresent wrench. (then measured the gap in the wrench), and I came up with about an inch and a quarter. I think I have a 32 mm bar as it is stock. 2000 4X4 1500. I was hoping to tap into All Ya' ALLs knowledge before I order the new stuff. Thanks for you help guys.
Old Apr 11, 2008 | 08:39 AM
mstephen89's Avatar
mstephen89
Default RE: What size is my sway bar?
Buy a micrometer this will allow you to get a better measurement. Or just ditch the swaybar, you dont need one anyhow.
Old Apr 14, 2008 | 08:23 AM
nateblong's Avatar
nateblong
without buying a mic. anyone know what size it should be ?
Old Apr 14, 2008 | 08:57 AM
Silver_Dodge's Avatar
Silver_Dodge
When I did mine, it was 32mm. Service manual says that there was two different ones though, a 30mm and a 32mm. Seems the most common is the 32mm though.
Old Apr 14, 2008 | 12:52 PM
nateblong's Avatar
nateblong
Thanks alot Silver_Dodge. I was leaning towards the 32mm bar. Its just that I wanted another opinion before I ordered. Thanks again.
