found plenum leak
Old Apr 12, 2008 | 03:53 PM
erikb45's Avatar
erikb45
Default found plenum leak
can a plenum leak cause a decent amount of power loss?
while changing the cap and rotor today i cleaned the throttle body and found some oil down in the intake. wondering if this is my cause of no power.
p.s. what a stupid spot for distributor cap.... broke wifes mirror in the process!!
Old Apr 12, 2008 | 03:55 PM
dodgeram07's Avatar
dodgeram07
Default RE: found plenum leak
bottom end power
Old Apr 12, 2008 | 07:55 PM
jasonw's Avatar
jasonw
Site Moderator
Yes, it can cause a low end power loss, as well as a decrease in your gas mileage.
Am I the only one here so far who hasn't had his plenum break? Just thought I'd ask...
Old Apr 12, 2008 | 08:03 PM
pipeking's Avatar
pipeking
i think so jason.ive never meet anyone who hasnt had to fix that problem.
Old Apr 12, 2008 | 08:36 PM
rabbler's Avatar
rabbler
Still have original plenum gasket. No leaks as of yet...
Old Apr 12, 2008 | 08:48 PM
Jr. Mechanic's Avatar
Jr. Mechanic
ORIGINAL: jason.w
My dads first 98 lasted 150,000 on the orignal plenum gasket (until it burned to the ground, RIP.) His current 98 has 170,000 and never had a plenum leak. Both were on original trannys too, except his current 98 just had a rebuild as it was leaking fluid out of the front main, still shifted fine though. My uncle's 96 is also fine with 130,000 one it.
Old Apr 13, 2008 | 08:34 AM
erikb45's Avatar
erikb45
thanks guys. my truck just turned 100K but now i think the plenum has been leaking since i got it at 78K. any way gonna set up to do this fix soon. maybe this weekend coming up
Old Apr 13, 2008 | 08:58 AM
Gone Campin's Avatar
Gone Campin
causes two problems: (1) adds air and screws up your A/F ratio, going lean, and poor combustion, and (2) loss of vacuum so your computer never knows the exact amount of power it needs.
It should be a "noticeable" loss in power... just plain poor performance. Something you would notice if you remember how the truck was performing before the problem. A big enough vacuum leak should eventually show on the CEL.
Old Apr 13, 2008 | 10:53 AM
erikb45's Avatar
erikb45
campin i believe it had the leak when i bought it so maybe it will be a good power gain for me.
felpro is the gasket of choice around here right?
where do you get new intake bolts from?
Old Apr 13, 2008 | 10:58 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: jason.w
I havent. I changed mine at 170 though.
