brak problems
Old Apr 12, 2008 | 07:27 PM
fuct33's Avatar
fuct33
Default brak problems
I got a 94 ram 4x4 7"lift and i've been having a problem with the brakes latley (it pulled to the right and vibrated) anyway I got new rotors that didnt fix it so I got new calipers then after putting them on I had no pedal at all (went right to the floor wont build pressure) so I got a new master cylinder that still didnt help no fluid is leaking any suggestions or tips I am losing my frickin mind on this one please help!!!!!
Old Apr 12, 2008 | 07:32 PM
98DodgeRam1500's Avatar
98DodgeRam1500
Default RE: brak problems
Waita min, slow down...
So, why did the rotors not fit? Wrong part or were the ones on there larger?
Why would you get new calipers??
Why would you get a new master cylinder?
new calipers should be replaced when the boot is torn, leaking or ceased.
a new master cylinder is rarely ever replaced.
I would have to know how you went about replacing your caliper... I am guessing you didn't bleed it fully.
Did you ever get a new rotor for your other side? its always best to do the same thing to the otherside.
Old Apr 12, 2008 | 08:05 PM
fuct33's Avatar
fuct33
sorrry I replased rotors (rotors did fit)caused I thought they were warped both sides I replased both calipers cause my boots were torn on both I thought one side was sticking I replased master cylinder cause after putting calipers on and bleeding them I could still turn tires with someone holding pedal to floor when you push on brake its like nothing is there I bleeded the mastercylinder like I said process of elimination so what do I check pinched brake lines or what im lost
Old Apr 12, 2008 | 08:19 PM
Dontdodgeitramit's Avatar
Dontdodgeitramit
My best guess is to bleed all the brakes. Cause about the onl thing you have left to check is air in the system. When you bleed the brakes do you hold down the close the screw? Cause if you dont it cancells itself out. Dont mean to rip on ya if ya know what your doin' jus tryin to help.
Old Apr 12, 2008 | 11:15 PM
fuct33's Avatar
fuct33
Yea I did that but I guess it wont hurt to try it again either that or try gravity bleeding them it just sounds like there air in there but wont come out
Old Apr 12, 2008 | 11:25 PM
padodgeram's Avatar
padodgeram
ORIGINAL: fuct33
You scare me ....
Old Apr 13, 2008 | 06:15 AM
98DodgeRam1500
ORIGINAL: padodgeram
You scare me ....
+1
Old Apr 13, 2008 | 09:14 AM
Gone Campin's Avatar
Gone Campin
ORIGINAL: 98DodgeRam1500
You scare me ....
+1
+2
get rotors to match stock, replacing an axle at a time. Then get a pro to bleed your brakes. Did your master cyl come with bench bleed instructions? you probbaly have good parts, just need to get them installed properly so you don't kill someone out on public streets.
Old Apr 13, 2008 | 09:37 AM
fuct33's Avatar
fuct33
yes I did bench bleed the master cylinder and yes the rotors are stock and for all these other mother ****ers that say im going to kill someone or I dont have a clue what im doing to hell with all of you im just some one that has a problem and lookin for a simple answer to my question and now im getting cut down like this you people scare me so **** off!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 13, 2008 | 10:40 AM
hometheaterman's Avatar
hometheaterman
Sounds to me like your brakes need bleeding some more. How did you bleed them?
