4wd light?
RE: 4wd light?
ORIGINAL: jason.w
Yep, if it never lights up at all, even when you first turn on the truck, I bet you're probably just looking at a burned out bulb.
I've heard of them burning out before, although its not to common. I'd definitely check it out.
to test the light, disconnect the elec connector from the end of the cad, and connect a jumper between the 2 contacts on the plug. light should come on.
this light is controlled by a contact or pressure switch inside the cad. when the shifting fork moves over towards the drivers side and connects the axles, it also depresses the plunger on the switch, which turns the light on.
a common problem with no light, but 4wd engaged - disconnect that elec switch and spray it with wd40 or contact cleaner. get all the mud, sand, etc out of the switch. it will work better. the switch can also be replaced for under $20 at most auto parts stores. mine didn't work because it was full of sand. easy fix.
http://www.dodgeram.org/tech/repair/..._engagment.htm
http://www.4x4wire.com/dodge/tech/solid_axle_cad/
Tim - your light coming on/off slowly is probably an indication that your shifting mechanism is very sluggish. typical of vac cad. the light is probably telling you the truth.
Trending Topics
RE: 4wd light?
ORIGINAL: dhvaughan
i'm going to disagree. the 4wd light does not come on when you turn the truck to on. it also does not come on during the gauge test ( turn sw on while holding odometer trip meter in, digital odo only).
[sm=oopssign.gif]
