160 or 180 deg thermostat??????
Old Apr 16, 2008 | 01:59 AM
padodgeram's Avatar
padodgeram
Default RE: 160 or 180 deg thermostat??????
ORIGINAL: RamItOne
the two stage 180s wont throw a code.... in theory the gas will burn better in a hotter environment, so dropping your temp down by 35 degrees may not give you a clean burn.... also if you live in the north you should stick with stock, maybe 180....
Whats a two stage 180s ??? Droping temp down 35 degrees ??? factory tstat is 195 , im lost here. here in pa i run 180 so far no problems .
Old Apr 16, 2008 | 02:54 AM
RamItOne's Avatar
RamItOne
the 35' was referring to the 160f
I'll google a pic of a two stage, on my iPhone so I'll do it tom when I'm on a CPU.
Old Apr 16, 2008 | 01:50 PM
sam18142's Avatar
sam18142
thanks guys. i'll go for 180 deg.
Old Apr 16, 2008 | 02:59 PM
HammerZ71's Avatar
HammerZ71
Here's a Jet 180* for a 5.2/5.9, it won't throw a code, is stainess and has a lifetime warranty for under $15.
I have a Jet in my Hemi, but for the Hemi is costs twice as much...[:@]
